mbyka
Full Member level 5
- Joined
- May 12, 2002
- Messages
- 299
- Helped
- 12
- Reputation
- 24
- Reaction score
- 10
- Trophy points
- 1,298
- Location
- from istanbul in TURKEY
- Activity points
- 2,125
i need simple but stabil adjustable DC 0-25v 3A or 5A support supply schematic for my 24v dc motor.
i dont want to use for control the motor with any buck boost converter becaouse motor cable wil be long(3meter) to control board.
For that reason i want to control my dc motor voltage range 0-25 dc with out voltage of lm2576 it has suport 3A or lm2596 has support 5A(it is better)
i want to use picf16877 pwm out to change regulator out voltage
but my analog electronic level is not enough to modify lm2576/lm2596 with my own self op-amp knowlege
so why i want help from you.
thank you .
thank you .
