[Help] run DC under Linux
syncom
Junior Member level 3
to all:
I install synopsys DC under Redhat 8.0,But when I try to execute "read file/analyzer file" commond in the GUI ,DC will be closed and jump back to shell.Then It will show a Error message ,anybody help me please!!!
below is the Error message ...
Initializing...
Error id=489925
Fatal: Internal system error, cannot recover.
You can use SOLV-IT! Fatal Hunt to search for articles that may
be related to this error.
If you wish to use SOLV-IT,please complete the following steps:
1. Copy and paste everything between the dotted lines into
the body of an email message.
2.Replace <your synopsys registered email address> with the email address
you use to access the SolvNET system.
3.Please email the message to solvit@synopsys.com.
------------------------------cut below this line-------------
start:
email: <your synopsys registered email address>
getfatal:
release ="2002.05" Architecture ='Linux" Program = 'design_analyzer'
'162872448 162872694 1107463240 162842062 134751985 163754020 163754537 163407129 163406764 163853474 163781718 163782942 163783092 163783763 163783720 134545515 134538837 '
end:
-----------------------------cut above this line
Thank you very much!
Maybe because of license
Change version of DC
syn2003 -linux work on the redhat 7.2 box
it is the bug of syn@psys software, try another version, i have encountered same thing in legal or illegal version of this.
in addition, try to use shell or GUI, it is less possible to crash
it's a bug.use higher version or read source file by the shell,then use gui
Yes, you'd rather change version, but latest version also some bugs...
design-vision and psyn-gui cannot start gui directly as typing command line...
then gui is crashed..
%design-vision -no_gui
design-vision>start gui
It is a bug of DC for Linux on any version, solution is under GUI use command window to read in the script file or RTL source, the other process were ok. just avoid to use read command box will be no problem.
