Help required for ST7920 GLCD with Arduino GLCD
chi239
Newbie level 6
Newbie level 6
Help required for ST7920 GLCD with Arduino Uno
Hello there,
I am a newbie with Arduino. I have hooked up a ST7920-based GLCD display with an Arduino Uno. I can display the first page OK. I want to display the next page when a pushbutton (SW1), connected to D11, is momentarily pressed. I cannot use any interrupt pin as both the interrupt pins (D2 and D3) have been used.
Can anyone tell me how to do this?
My code is as below:
#include "U8glib.h"
#include "max6675.h"
U8GLIB_ST7920_128X64_1X u8g(7, 6, 5 ,8); //Enable, RW, RS, RESET
// Used for generating interrupts using CLK1 signal
  const int CLK1 = 2;
  // Used for reading DT1 signal
  const int DT1 = 9;
  // Used for generating interrupts using CLK2 signal
  const int CLK2 = 3;
  const int DT2 = 10;
  // Used for the push button switches
  const int PinSW1 = 11;
  const int PinSW2 = 12;
  // Keep track of last rotary value
  int lastCount1 = 50;
  int lastCount2 = 50;// this is the temp in Centigrade
  int lastCount3;// this holds the temp in Fahrenheit
  int curr_temp;// This is the current temperature
  // Updated by the ISR (Interrupt Service Routine)
  volatile int virtualPosition1 = 500;
  volatile int virtualPosition2 = 500;
char tmp_string1[8];
char tmp_string2[8];//Centigrade
char tmp_string3[8];//fahrenheit
char tmp_string4[8];// current temperature (C);
bool tempFlag = false;// to display "C"
int ktcSO = A5;
int ktcCS = A4;
int ktcCLK = A3;
MAX6675 ktc(ktcCLK, ktcCS, ktcSO);
void setup() {
  u8g.setFont(u8g_font_7x14B);
  u8g.setColorIndex(1); // Instructs the display to draw with a pixel on.
  // Rotary pulses are INPUTs
    pinMode(CLK1, INPUT);
    pinMode(DT1, INPUT);
    pinMode(PinSW1, INPUT);
    pinMode(PinSW2, INPUT);
    pinMode(CLK2, INPUT);
    pinMode(DT2, INPUT);
    // Switch is floating so use the in-built PULLUP so we don't need a resistor
    //pinMode(PinSW, INPUT_PULLUP);
    // Attach the routine to service the interrupts
    attachInterrupt(digitalPinToInterrupt(CLK1), isr1, LOW);
attachInterrupt(digitalPinToInterrupt(CLK2), isr2, LOW);
void loop() {
    if ((!digitalRead(PinSW2)) && (tempFlag == false))
    tempFlag = true;
    else if ((!digitalRead(PinSW2)) && (tempFlag == true))
      tempFlag = false;
 while (!digitalRead(PinSW2));
      delay(10);
 if (virtualPosition1 != lastCount1) {
      // Write out to serial monitor the value and direction
      // Keep track of this new value
      lastCount1 = virtualPosition1 ;
      if (virtualPosition2 != lastCount2) {
      lastCount2 = virtualPosition2 ;
 u8g.firstPage();
  do {
    draw();
  while( u8g.nextPage() );
void draw(){
  lastCount3 = (((lastCount2 * 9)/5) + 32);
     itoa(lastCount1, tmp_string1, 10); // [url]https://www.avrfreaks.net/forum/how-do-i-print-variable-u8glib[/url]
     itoa(lastCount2, tmp_string2, 10);
     itoa(lastCount3, tmp_string3, 10);
  u8g.firstPage();
  do {
  u8g.drawStr( 54, 12, "SET");
   u8g.drawStr( 20, 30, "SPEED");
   if (tempFlag == false)
    u8g.drawStr( 76, 30, "TEMP(C)");
   else
    u8g.drawStr( 76, 30, "TEMP(F)");
  u8g.drawStr(28, 50, tmp_string1);
  if (tempFlag == false)// that is Centigrade
  u8g.drawStr(80, 50, tmp_string2);
   else
    u8g.drawStr(80,50,tmp_string3);// fahrenheit
//delay(10);
while (!digitalRead(PinSW1))
u8g.firstPage();
do
draw2();
while (u8g.nextPage());
  //delay(5000);
void draw2(){
  u8g.drawStr( 50, 12, "CURRENT");
curr_temp = (ktc.readCelsius());
      itoa(curr_temp, tmp_string4, 10);
       u8g.drawStr(60, 60,tmp_string4);// current temperature
  void isr1 ()  {
    static unsigned long lastInterruptTime1 = 0;
    unsigned long interruptTime1 = millis();
    // If interrupts come faster than 5ms, assume it's a bounce and ignore
    if (interruptTime1 - lastInterruptTime1 > 5)
      if (digitalRead(DT1) == LOW)
        virtualPosition1 = virtualPosition1 - 10 ;
         if (virtualPosition1 <=100)
          virtualPosition1 = 100;
      else
        virtualPosition1 = virtualPosition1 + 10 ;
        if (virtualPosition1 >=1000)
          virtualPosition1 = 1000;
    // Keep track of when we were here last (no more than every 5ms)
    lastInterruptTime1 = interruptTime1;
  void isr2 ()
        static unsigned long lastInterruptTime2 = 0;
    unsigned long interruptTime2 = millis();
    if (interruptTime2 - lastInterruptTime2 > 5)
      if (digitalRead(DT2) == LOW)
        virtualPosition2 = virtualPosition2 - 10 ;
         if (virtualPosition2 <=100)
          virtualPosition2 = 100;
      else
        virtualPosition2 = virtualPosition2 + 10 ;
        if (virtualPosition2 >=1000)
          virtualPosition2 = 1000;
    lastInterruptTime2 = interruptTime2;
