A and B are coil terminals where u applied voltage directly 12vdc
and the rest of Pole NC(normally close) NO(NOrmally open) pole is common to NC NO.
you can choose any one configuration as normally open or normally close according to ur requirment (220v or the voltage u want to controll as open or close switch)
looking on the symbol which is marked and i think it is single pole single throw relay.
When you apply voltage on the coil, it will get closed. Bottom 2 pins are coil .
On the right, it is common.
on the left, you can see 2 pins. One on the top left is NC and second from top left is NO. In your case, you should not use NC pin because it looks like SPST.
There are 2 configurations, form A and form C. Please check the ordering code which one you have bought. All the information is specified in the datasheet.
yes MYMELON no problem in relay coil either u connect positive to B and negative to A or voice verse it doesn't matter , polarity doesn't matter in relay
