help regarding this diagram
santumevce1412
Junior Member level 2
design the circuit that produces the attached output.
whenever an i/p is detected at an edge of a clock, the o/p is to be one for that clock cycle and after that o/p is to be zero for any i/p in the remaining cycles.
pls find the diagram attached.
use FSM
u ll be able to do it easily
assign int=input|output
always @(posedge clk)
output<=int
syntax is not accurate... but logic should be correct.
assuming that output is initialized to '0'
Added after 6 minutes:
sorry... earlier solution is wrong... the following should work... assumes all flops initialized to zero .
assign int_a=input|int_b;
begin
int_b<=int_a;
int_c<=int_b;
end
assign output=(~int_c)&int_b;
the above verilog code is working thank u for u r help
i have asked one more question pls check u r inbox
