help regarding struct in C++
Virus King
Member level 2
JaMaN RoAd BaNnU
all of us know that by using int,float,char before main(), we have to use return 0; in the end of program. as shown below
int main()
return 0;
as we know that int float char are abstract data types.
and struct is composite data type, so by using my composite data type why turbo c compiler gives us error as shown below
struct student
int class;
float gpa;
student main()
student s1;
cout<<"plz enter class and gpa";
cin>>s1.gpa>>s1.class;
return 0;
AA,
Please attach the compiler message.
Regards,
amraldo
the error genrated by compiler is
cannot convert int to student datatype
bcoz int is abstract data type and student is composite data type.
AA,
try to modify the line student main to struct student main , in addition to modifying the return statement to return a variable of type sturct student.
Keep me updated.
Regards,
Amraldo.
This works for me: (compiles and links without error or warning)
struct student
int StudentClass;
float gpa;
student main(int argc, char* argv[])
	student Me;               // creates a student-structure
	Me.StudentClass=1;  // assigns the int value 0 to the 1st part of structure
	Me.gpa=9.99f;          // assigns the float value 9.99 to the 2nd part of structure
	return Me;                // let main end with returning (with the values of)
                                       // the student-structure Me.
The warning you recieve is because in your code (return 0 you tell the compiler to return 0 while you specify also that the return type should be of the struct student.
Advise : stay away from using reserved names like 'class' for variables, especially in c++.
Success with your code.
Jeroen
    Virus King
