[Help]RedHat 7.2 installation
RFID
Junior Member level 1
I downloaded RedHat 7.2's ISO image files from redhat's website,
and then wrote them to CDs.
I booted the computer from floppy disk,
and went down the installation,
when it read the information from CD-ROM,
an error message occured:
I could not find a Red Hat Linux CDROM in any of your CDROM drivers.
Please insert the Red Hat CD and press"OK" to retry.
what's the problem?
what should I do?
thanks
red hat cds are bootable so there is no need to boot from floppy.
go to bios setup and change boot sequence to boot from cdrom first.
then insert the cd1 in cdrom and start the installation.(it is also autorun)
if u need in detail help for installation specially for partitioning see:
https://www.redhat.com/docs/manuals/linux/RHL-7.2-Manual/install-guide/
BEST!
Hello,
I believe the CD1 should be a bootable CD... Change your bios setting to boot-up from cdrom, then done the installation.
Regards,
thanks,
I already solved this problem.
change bios setting and boot from CD with CD1.
