[help] receiving code of can controller lpc2129
jjeevan007
Full Member level 5
Full Member level 5
bangalore
hi to all,
i am implementing can protocol using two LPC2129 controller
one is sending data and one is receiving data....
here is code for sending
#include<lpc21xx.h>
unsigned int val,n,fs,id,data;
unsigned char i=0;
void CAN_init()
unsigned int * pAddr;
pAddr  = (unsigned int * )0xE0038000;
//DWORD *pAddr;
PINSEL1 |=0x00040000;
C1MOD = 0x01;
C1GSR = 0x00;
C1IER = 0x02;
C1BTR = 0x001C001D;
C1EWL = 0xff;
C1MOD = 0x00;
//pAddr = (DWORD *) AFRAM;
AFMR = 0x00000001;
SFF_sa = 0;
*pAddr = 0x211f20cf;
pAddr++;
*pAddr = 0x206B2064;
SFF_GRP_sa = 0x00000008;
EFF_sa = 0x00000008;
EFF_GRP_sa = 0x00000008;
ENDofTable = 0x00000008;
AFMR = 0x00000000;
void MSdelay(unsigned int rtime)
	unsigned int r,s;
	for(r=0;r<rtime;r++)
	for(s=0;s<7500;s++);
int main()
unsigned int i='a';
//unsigned int status;
CAN_init();
PINSEL0=0;
IO0DIR= 0x000000ff;
while(1)
while((C1SR & 0x00000004) != 0x00000004);
C1TFI1 = 0x00040000;
C1TID1 = 0x000000CF;
C1TDA1 = i;
C1CMR = 0x21;
//val=C1ICR;
//while((C1GSR & 0x00000008) != 0x00000008);
//status = C1GSR;
//status = C1GSR;
		IO0SET = 0x000000ff;
		 MSdelay (1000);
  		 IO0CLR = 0x000000ff;
		 MSdelay(1000);
here is code for receiving
#include<lpc21xx.h>
unsigned int val,n;
void CAN_init()
C1MOD = 0x01;
C1GSR = 0x00;
C1IER = 0x00;
C1BTR = 0x001C001D;
C1EWL = 0xff;
C1MOD = 0x00;
AFMR = 0x00000001;
pAddr++;
AFMR = 0x00000000;
	unsigned int r,s;
void lcdcommand(void)
			 MSdelay(6);
			 IODIR1=0X00FF0000;				/* P1.16..23 defined as Outputs  */
			 IOPIN1 = n;
			 IOCLR0=0x00000010;	   			/* RS(P0.4)=0  */
			 IOCLR0=0x00000020;				/* R/W(P0.5)=0  */
			 IOSET0=0x00000040;				/* EN(P0.6)=1  */
			 IOCLR0=0x00000040;				/* EN(P0.6)=0  */
void lcddatawrt(void)
			MSdelay(4);
			IOPIN1 = n;
			IOSET0=0x00000010;				/* RS(P0.4)=1  */
void lcd_initialization(void)
		//PINSEL1=0x00000000;				/*MAKE 0.28,0.29,0.30 AS I/O*/
		//PINSEL2=0x00000000;				   /*MAKE 1.16...1.23 AS I/O*/
	   	n=0x00380000;
		lcdcommand();
		n=0x000c0000;
		lcdcommand();
		n=0x00060000;
		lcdcommand();
		n=0x00010000;
		lcdcommand();
int main()
//unsigned int temp;
PINSEL0=0;
IO0DIR= 0x000000ff;
lcd_initialization();
CAN_init();
n=0x00310000;
lcddatawrt();
while(1)
n=0x00310000;
lcddatawrt();
while ((C1GSR & 0x00000001) !=0x00000001)
		 IO0SET = 0x0000000f;
		 //MSdelay (2000);
  		 //IO0CLR = 0x0000000f;
		 //MSdelay(2000);
IO0CLR = 0X0000000F;
//n=0x00310000;
//lcddatawrt();
//temp=C1RFS;
	if((C1RFS & 0x40000000)!=0x40000000)
	 	n=0x00310000;
		lcddatawrt();
		//if((temp & 0x80000000) == 0x80000000)
		if (C1RID == 0x000000CF)
			 val = C1RDA;
			 n=val<<16;
			 lcddatawrt();
		else;
		C1CMR = 0x00000004;
C1TDA1 = i;
C1CMR = 0x21;
//while(1);
in simulating i can able see sending of data correctly,
but i am not able simulate the receiving part so help me with receiving part of my code
regards
jeevan
zip and post your simulation file. is it proteus simulation? What is your problem?
What I see in your receiving code is that you have two while loops, but there is no braek statement for inner while loop i.e., no break for the code
		 //MSdelay (2000);
		 //MSdelay(2000);
Can you zip and post the simulation file and your code file?
Reactions: ASHIF
    ASHIF
ok i will try with it
hi i am new to ARM ... doing project in CAN only ... plz help i dont know how to start code for CAN .... somewhat can able to understand code !!!
but in simulation only transmission message displaying ... how to conform both r communicating? pls share ur Knowledge
Thank you
Reactions: ASHIF
    ASHIF
receiving of the CAN can not simulated in LPC2129................
do u have a written code then post it so that we can help u..........
