Help Proteus Package
brian25
Member level 2
Member level 2
i want to make new device in proteus but i don't know when to use the electrical types configuration
(passive, input, output, pullup etc..)
example if i want to make device Q4004l4(triac)....... where should be the passive, input and output pin here?
thanks
You need to write code to create simulation model and compile it to create a .dll for your model. To create schematic (non sim) model you can use the method you have shown. For schematic model it doesn't matter what electrical type you choose for pins. It is required only for sim model.
