tony_taoyh
Full Member level 2
I am doing a high precision ADC testing (15bit).
The power supply is used to power up the DUT, also to generate the reference voltage.
Which option is better?
1) Use power supply's output directly, i.e., HP E3631A;
2) Use power supply's output to drive the one regulator, then the regulator's output is used to drive the testing board.
Thanks a lot.
Thanks a lot.
