AyanamiR
Newbie
Hi. I need to convert code from mikroC PRO for 8051 to Keil uVision5.
Thanks for the help.
[moderator action: corrected formatting tags]
* SW:
mikroC for 8051 v2.2 [URL]http://www.mikroe.com/[/URL]
* Test configuration:
- MCU: AT89С51
Oscillator: External Clock 12.000 MHz
sbit DIG1 at P1_5_bit;
sbit DIG2 at P1_6_bit;
sbit DIG3 at P1_7_bit;
// Software SPI
sbit SoftSpi_SDI at P1_1_bit;
sbit SoftSpi_CLK at P1_0_bit;
sbit SoftSpi_SDO at P1_3_bit;
sbit SPI_CS at P1_2_bit;
const char TH1_INIT = 0xE8;
const char TL1_INIT = 0x00;
unsigned char digit[3], i, k;
unsigned int Temp, T_ADC;
unsigned char Led_Table[10] = {0b00111111, // 0
0b00000110, // 1
0b01011011, // 2
0b01001111, // 3
0b01100110, // 4
0b01101101, // 5
0b01111101, // 6
0b00000111, // 7
0b01111111, // 8
0b01101111}; // 9
void Strob (void)
SoftSpi_CLK = 0;
Delay_us(7);
SoftSpi_CLK = 1;
Delay_us(7);
void Read_ADC (void)
T_ADC = 0;
SPI_CS = 0;
Strob();
Strob();
for (i=0; i<13; i++)
SoftSpi_CLK = 0;
Delay_us(5);
T_ADC = T_ADC << 1;
if (SoftSpi_SDI) T_ADC = T_ADC | 1;
SoftSpi_CLK = 1;
Delay_us(10);
SoftSpi_CLK = 0;
SPI_CS = 1;
return;
void Timer1InterruptHandler() org IVT_ADDR_ET1
EA_bit = 0;
TR1_bit = 0;
TH1 = TH1_INIT;
TL1 = TL1_INIT;
P2 = Led_Table[digit[0]];
DIG1 = 0;
Delay_ms (3);
DIG1 = 1;
P2 = Led_Table[digit[1]];
DIG2 = 0;
Delay_ms (3);
DIG2 = 1;
P2 = Led_Table[digit[2]];
DIG3 = 0;
Delay_ms (3);
DIG3 = 1;
EA_bit = 1;
TR1_bit = 1;
void main()
P0 = 0;
TF1_bit = 0;
ET1_bit = 1;
EA_bit = 1;
GATE1_bit = 0; // Clear this flag to enable Timer1 whenever TR1 bit is set.
C_T1_bit = 0; // Set Timer operation: Timer1 counts the divided-down systam clock.
M11_bit = 0; // M11_M01 = 01 => Mode 1(16-bit Timer/Counter)
M01_bit = 1;
TR1_bit = 0;
TH1 = TH1_INIT;
TL1 = TL1_INIT;
TR1_bit = 1;
P2 = 255;
Soft_SPI_Init();
digit[0] = 0;
digit[1] = 0;
digit[2] = 0;
do
TR1_bit = 0;
Read_ADC();
TR1_bit = 1;
Temp = T_ADC * 9;
Temp = Temp / 37;
digit[0] = (Temp/100) % 10;
digit[1] = (Temp/10) % 10;
digit[2] = Temp % 10;
Delay_ms(1000);
while (1);
