Help: Please give me a example code of compact flash(CF)
mountain
Member level 2
Member level 2
compact flash code example
I want to use a ARM or Hitachi H8 CPU to read and write the compact flash(CF), because a great deal of data should be stored in the compact flash like stored in a hard disk. But I don't know how to control the compact flash like a hard disk.
If anyone have the C code for example? Thank you!
source code emif flash silabs
Me too ! My boss ask me to do some work about CF card . He want use it as a storage.I only get CFA specification online,i need some example.If anyone have some advice ,please tell me .Thank you very much !
compact flash example code
Please check this link: **broken link removed**
THis project not involve all C programming but have assembly language for PIC mcu.
Wish you good luck in your project.
interfacing cf
Hello
Search silicon lab site app note for the 8051fxxx thay have nice app note with c language code for interfacing CF card for data logging
site : www.silabs.com
All the best
Bobi
Doubt in Compactflash
Hi all,
I am using a 4gb compact flash. I am also interfacing it with a CPLD and a TI DSP.
But in the memory map of the dsp only 256MBytes of block address is mapped to the compact flash which is a 4gb device. The TI dsp uses the EMIF device to interface with the CF. Can anybody explain this. Also if anybody has a Source code for COMpactflash read/write in C, please send it acros. It will be of gr8 help to me.
thank you,
jeechu
