Help please - comparing analogue to a digital FIR filter
weedeek182
Newbie level 1
Newbie level 1
Help please.....
Good day. Right, basically i'm doing a module at Uni, that i have no clue about, and i am in some need of help.
I am designing an analogue filter (active 2nd order LPF) and comparing it to a digital FIR filter.
I have one query that i have been trying to get an answer for, but its not exactly the type of thing you can type straight into a search engine.
Here it is: when you design the filter for analogue you represent the graph as a voltage response and when its digital it is in dB's. Is this right???
I am using Schematics from PSpice and Matlab. Is there a way to get both as voltage or in dB's.
Also, a 1st order LPF will have 2 resistors and 1 capacitor and a 2nd order has 2 resistors and 2 capacitors. Is this right??? please help!!
Re: Help please.....
I suggest you read this ,
https://en.wikipedia.org/wiki/Electronic_filter
Now dB has nothing to do with if it's Analog or digital filter .And you can get results in the simulation in dB and Voltage both . Normally when you do AC analysis it gives the vertical axis as Voltage but you can change it to 20*log(Vout/Vin) that's dB.
And now your question on order , each recative element(capacitor or inductor) means order. So two capacitor means 2nd order filter, genrally speaking
