hmsheng
Full Member level 4
lna in series with pa
Generally, in RF transceiver, PA/LNA connect to antenna through a T/R switch. For time division system, such as Bluetooth, how if we connect PA and LNA together? That is, in TX mode tune on PA and turn off LNA, in RX mode turn on LNA and tune off PA. Most of such products and papers are designed with T/R switch. Why?
If we connect PA/LNA together and PA output power is 3dBm to 50 Ohm antenna, can the large PA output swing destroy LNA input device (NMOS, 0.18um)?
Regards,
HM
Regards,
HM
