help on voltage isolator
alec82
voltage isolator
hi guys
i need to make voltage isolator via optocopler .
anybody have idea to do that?
appreciate in advance
hcpl7510 application notes schematic examples
Hello!
Look at the following datasheets.You will find the circuit you need for and also the schematic.
Best regards!
Venix
    alec82
il300 isolator
hello
i want to isolate a signal that varied from 0 to 5 volt ? how i can do this?
regards
volt isolators
Vishay IL300 with a feedback circuit as suggested in the datasheet can do.
    alec82
hcpl 7520 schematics
Or you can use a voltage sensor optocoupler like HCPL-7510/7520
The input range can be adjusted to +-320mV with resistor bridge. Output is given with a good linearity.
Cheers
Hakeen
voltage isolator 4
Hi
at 1st you need to convert the signal to Pulse by VCO,then use an OPTO coupler,and again convert the OPTO coupler OUTPUT pulse to voltage.
THere is many prefab circuit for this purpose.
    alec82
iso4 opto
Look-up LOC110 made by Clare. It will need feedback amplifiers. The datasheet for the chip has good application circuits. Keep in mind that most linear optocouplers have a limited bandwidth. I have not seen a linear optocoupler with BW > 200kHz. What kind of signal do you want to isolate? What's you application, if it's not a secret?
induction isolator
hi friends
i'm going to use voltage isolator(actually signal isolator ) for sensing output voltage and current in smps circuits that have different ground .
i'm using pic mcu as controller and i want to isolate input analog signals.
best regards .
voltage isolator 12 volt
Hi, you don't have to do it yourself.
Sunyuan ISO A(U)-P-O or ISO 4-20mA series will do. They have been making this part for years and you can count on them. Small, precise and inexpensive.
Check
linear optocoupler isolator
dear sunyuan
above link is dead
r u sure the link typed correctly?
regards
Check
hcpl7510 as voltage isolator
Hi
This is what I used in the past. Just resistor bridge, with one of them is shunt for isolation amplifier.
Hope it helps
    alec82
diy linear optocoupler circuit
Most often questions of concern arise to anyone associated with the use of any communication signal via a metallic or fiber optic cable. Providers of telecommunications, electric service, wireless service or CATV, or operating in an isolated manufacturing or mining location, may be working in a hostile electric environment. An unprotected or improperly protected system is unsafe for the public and personnel, and exposes equipment to service interruptions or permanent damage.
hcpl 7510 application bandwidth forum
dear friends
anybody knows anythings about induction isolator ?
best regards
