Help on verilog code!
yann_sun
Member level 1
Member level 1
Hi, all
Why the commands in "always begin end" executed at the time zero?
The following is the brief codes.
initial begin
A <= 0;
# 10 A <= 1;
end
always @(negedge A) begin
some commands
some more
end
A is not a clock signal, so it is level triggered, not edge triggered.
Non-blocking assignment A <= 0; bring delta-cycle, this expression equivalently #0 A=0;
Use A=0; instead A <= 0; for solve this problem.
Using A=0 still fails to solve the problem. There is no discrepancy. Any hint?
If you are using any simulator that support SystemVerilog, if you write your code as
reg A = 0;
The initialization of A is guaranteed to execute before any always or initial block execute.
Alternatively you could make the first assignment to A=1, but then you would have the problem for @(posedge A) if there are any.
Thanks Dave.
Where there is a will, there is a way.
that helps
because in verilog any signal default is X, intial begin A =0 end will bring A jump from X to 0, that's mean a negedge tigger
It means that "reg" gets executed before any other code/block , irrespective of priorities . but why "reg" gets executed first ?
reg A = 0;
