manikandan123
Member level 4
- Joined
- Jul 22, 2011
- Messages
- 76
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,288
- Location
- Bangalore,India
- Activity points
- 1,849
Already i know about precision rectifier.It good. but I need to put the diode after feedback for prevention purpose. It act as blocking diode. is any other ideas.... I want to get Vout of opamp is input+drop voltage.so only it followed same input voltage after the diode... did u got it?BTW : the circuit that i attached will work fine , but not as well as possible ! do you want that i attach the best circuit for that ?
is any schematics?If you use Capacitor loading not resistor, you can get Vin = Vout
Are you sure ? how it is possible to compensate the drop diode of automatically without diode at feed back loop ?Already i know about precision rectifier.It good. but I need to put the diode after feedback for prevention purpose. It act as blocking diode. is any other ideas.... I want to get Vout of opamp is input+drop voltage.so only it followed same input voltage after the diode... did u got it?
you told correct Goldsmith. The capacitive load does not avoid the forward voltage drop. Precision rectifier is also good . thanks for all...Dear varunkant2k
Hi
As you probably know the gama voltage of silicon diode is about 0.6 volt . and thus you'll have this voltage across your diode . and thus your out put will be lower than your input . you can do it , just if you use that in an active feed back loop .
Respect
Goldsmith
Of course it's not possible.Are you sure ? how it is possible to compensate the drop diode of automatically without diode at feed back loop ?
No. It stores Vpeak - 0.6 V.Capacitor stores the average dc value of VIN.
In post #14, simulation result shows for dc as well as sin wave input, but output shows the dc value of input.Capacitor stores the average dc value of VIN.
Yes I agree to this point, performance may be affected at resistive loading.A non-feedback compensation could be implemented unter specific conditions, but can't achieve the same performance.
That's an example how you can easily get unrealistic results in simulation. During bias point calculation, capacitors are ignored, so Vout can rise to Vin with effectively zero (or fA) current. The capacitor will be charged through the diode leakage resistance.In post #14, simulation result shows for dc as well as sin wave input, but output shows the dc value of input.
I don't think so, everything is pretty plausible.your circuit destroyed some principles of diode !
