help on SPW 4.8.1 on linux
nanako
Member level 5
Member level 5
spw linux
i installed spw 4.8.1 on linux rh7.2 and i couldnt find the executable file "spw" in the dir $SPW_HOME/tools/bin
can some1 tell me what are the features for SPW also.
thanks
redhat 4.8 install openmotif
"spw" is a alias for SPW_HOME/caesys/nui/bin/mfileman.And you should execute the SPW_HOME/caesys/nui/bin/mfileman.If you could open "mfileman" ,please tell me how you install.
spw linux
the spw problem is solved but i now got an error when i run "spw"
the error is
"error while loading shared libraries: libMrm.so.3: cannot open shared object file: no such file or directory"
any idea ???
spw mfileman
eman said:
search for openmotif package and download openmotif-xxxxxx.rpm(e.g http://www.hklpg.org/RPM/rawhide/1.0/i386/RedHat/RPMS/openmotif-2.2.2-12.1.i386.html), after installing this package the problem is solved! Cadence installation docs should tell the user SPW needs this package.
eman
ok i managed to get the package openmotif-2.2.2-5.rpm and after i do a rpm -i openmotif-2.2.2-5.rpm, the following error appears
error: failed dependencies:
lesstif <= 0.92.32-6 conflicts with openmotif-2.2.2-5
any idea how to solve it ???
btw anyone can tell me the feature list of spw. thanks a lot
then please try other versions of openmotif package.
other newer version of the openmotif i can get is all xxxxx.src.rpm. i not very sure how to install the src rpm. can teach me.
I met with the same problem? How to settle it. Can anyone tell me ? Thanks!
I'm getting seriously pissed with Redhat. All the different versions have different non-compatible libraries.
How to get a complete flow without having to select back and forth between different versions during boot?
It is very disruptive to have to do simulation in one version of Linux, then reboot into another version of the same OS to do P&R, then re-boot to another version of the same OS to do extraction and LVS, and so on and so forth.
Well... just my 2 cent's worth.
ASIC
where is it?
plz help me.
i met the same problem, and i view the RH7.2 rpm package, it is different with RH7.3, in RH7.3 there is default openmotif package. so i will try spw on RH7.3
Can you please pm me if you have SPW software?
you must unstall the lesstif then install openmotif
use csh
source /site_data/config/spw.cshrc
spw
Glad to see everyone!
Oh, you should install all the required rpm packages , remember need not too new. Just above the required version is enough. Run cdsconf under tools.ln386(I don't remenber very exactlly), you could acquired all the required rpm packages and their version.
" lesstif " does the same work as openmotif, but openmotif is required, although openmotif may be not as good as lessif.
Don't try on RH7.3, it's just waste time unless you have 4.8.2.
Enjoying it!
