gudxors
Newbie level 5
Hello,
I am currently working on solar systems and DC-DC converters. Since this is a competely new topic for me, i have lots of questions and need some guidance. I have spent lots of time searching online, but couldnt get much information. Please, any help will appriciated.
First, i am designing a buck DC-DC converter, which takes inconsistant input voltage from the solar panels. The voltages generated by panels are varying from 200V ~ 300V, which is input voltage for the DC-DC converter, and i want to have 110V DC at the output so later i can inverter that to 110V AC by using full bridge inverter. I started with 10V buck converter using two IRFR320 mosfets and it worked well. However, when i increase my input voltage to over 200V, it is not really working well. i am using these values L=80mH, Cout=2.5uF, and duty cycle = 66% with 6us period. Any recommendations on component values or mosfet selection?
Second, since my input voltage varies, my output value varies as well. I want to have 110VDC at output even though the input voltage changes. What should i do for this?
By the way, i am planning on using a DSP based microcontroller to control the gates of mosfets. I figured that Texas Instruments have TMS320C2000 series for solar applications.
Thank you so much in advance.
Tyler
Tyler
