air
Member level 3
The noninverting input is connected to ground, inverting input connected to a voltage source through a resistor and another resistor form a feedback loop from output to inverting input. when the feedback resistor's resistance is huge like 100 M Ohm and above. there is no oscillation. but when the feedback resistor's resistance get smaller than tens M Ohm to the minimum like 10K. the output oscillation begin increase and getting bigger and bigger. How to fix this? Are there some references dealing with OP Amp trouble shooting practice? Thanks!
