mengghee
Full Member level 3
- Joined
- Nov 29, 2005
- Messages
- 163
- Helped
- 8
- Reputation
- 16
- Reaction score
- 5
- Trophy points
- 1,298
- Location
- United Kingdom
- Activity points
- 3,105
hiye everybody,
I have included a link below to the datasheet. I am just quite unsure about a few stuff. in the datasheet, it is written that the absolute maximum Vin differential is +-1.2. does that mean that 1.2v is the maximum value i can put in the positive pin or negative pin ? and also what is the difference between input resistance common mode and differential mode ? i am trying to use this op amp as a comparator to generate a pwm. and the datasheet of the sawtooth generator states that i need a load resistance of at least 50kohm. will this fit into the spec of the op amp ? thank you
http://www.datasheetcatalog.com/datasheets_pdf/L/M/H/6/LMH6655.shtml
regards,
mengghee
regards,
mengghee
