David2004
iip3 simulation in cadence
Normally I can get IP3 from PSS or PSS/PAC simulation in IC4.46, QPSS or QPSS/QPAC simulation in IC5.0. When I designed LNA before I can easily get a clear 3:1 slope. But when I use cadence to run the IP3 simulation over one single device, I can not get the same 3:1 slope no matter how I changed the tolerance parameters. I did not use matching network in my simulation as in LNA design, only for the device itself. Anybody met the similar problem before on IP3 simulation? Any suggestions? Thanks!
