Help on getting antenna measurements
nadabro
Member level 4
Hi.
Its been a long time i try to design a antenna. I´m trying to build a circular slotted antenna for 2.44Ghz based on the paper "On the Miniaturazation of Cylindrical Omnidirectional Slotted WaveguideAntennas for Wireless Applications"
According to a paper:
1) It uses a C22 waveguide.
97.87mm in diameter.
2) Lenght: "5 * guides wavelength".
5 * 181.5mm = 907.5mm
3) Space between slots is "half guides´s wavelength".
181.5mm / 2 = 90.75mm
4) Slots are spaced 2º from the centerline.
5) Slots length: 0.55λ0.
181.5 * 0.55 = 99.825mm
6) Slots width: 3.3% of slots length.
3.29mm
7) Probe at "quarter guide´s wavelength".
45.4mm
8) Antenna top reflector at 0.365λ0 from the last slot.
181.5 * 0.365 = 66.248mm
Are my calculations correct? I´m a bit confused between "guides wavelenght"..
What does mean 4) ?
Also in the paper i didint find any reference the distance between the probe and the first slot..
A image of the antenna is attached (got it from Google Images).
Thanks.
4 ) could mean radial offset of slots. If yo look at the picture - slots are not in line - one to the left, next t the right and so on. I imagine center line is drawn and slots offset from it 2deg each way.
I think it is, can not say 100%.
Thanks for the answer.
That makes sense, rectangular slotted waveguides have a offset from the center.
My big confusion is regarding "half guides´s wavelength" and λ0:
Guides wavelenght for a diameter 97.87mm at 2.44Ghz is 181.9, so half guides wavelenght is 181.9/2..?
λ0 is wavelenght in free space, for 2.44Ghz is 122.87, so 0.55λ0, is 0.55*122.87..?
@fiwi thats for rectangular waveguides , i´m looking for circular waveguides. I tried simulate that measurements in a circular waveguide and it does not work great..
...to remember.
Thanks for the schematic @fiwi.
Unfortunately according to a rude simulation i made (cant confirm or not), that schematic will not work well. The formulas that calculators provides maybe not work in a circular waveguide?
Anyhow, the schematic on rectangular waveguides is a bit different on the circular waveguide in image attached, particularly on the distance between probe and 1st slot.
You can show any antenna simulation?
