Help on file systems in Linux
asemnor
Junior Member level 3
Can you explain to me the differences between the various file systems in linux.Infact what is a file system?
the main file system is ext2/ext3 but you can use reiserfs in case you need high performance (with less reliability).
Anyway you can read any NTFS filesystem (write is not suggested so far), and read/write any FAT, HFS, ISO filesystem.
Ciao
AxeL
A "file system" in this context refers to the type of
layout, addressing, indexing, and access methods
of the data on the platter(s). Some operating
systems (notably Unix and Unix-based) can access
and/or actively use, filesystems from other operating
systems. The "file system" is created by the specific
formatting tools of the particular OS, and identified
in the partitioning table on the drive.
<als>
And there is another special partition file system special used by Linux its the swap in Linux you have to dedicate a partition for os swapping (nowadays you can skip also ) in windows environment it uses a file as a swap space this performance is slower than Linux as it uses a special partition itself.
ext3 ,rerisfs,xfs are journal file system, you will not lost data when you computer 's power is cut off.So they are safer than ext2.
