Joeadeoye
Junior Member level 2
I am trying to design a simple buck converter that will accept input of upto 150V and output 15V using the above circuit i got from the internet. After carefully checking the circuit, i became a bit confused and i would need some explanations from fellow engineers in this forum.
First is about the mosfet. The mosfet used is a N-Channel mosfet, and to fully turn on an n-channel mosfet, its source pin has to be reference to GND and if its not, then its gate pin has to be bootstrapped. Looking at the circuit diagram above, the source pin of the mosfet has no reference to ground, and the gate is not bootstrapped as well, so how will it work?
Second is the totem-pole at the output of the IC, it seems to be connected in reverse direction, is this intentional or a mistake?
Third is the UC3845 IC itself, the IC and all its external components have no reference to GND, instead the GND of the IC is tied to the source pin of the mosfet (which does not have GND reference either), so how is this suppose to work?
From this same circuit, i have seen two different Youtube videos that claimed to use this same circuit and it worked, but i'm a bit confused how manage it could work. Here are the links to the video for reference:
Please i need some explanations.
