HELP: No results after running HSPICE 2003.03 in IC5.0
exeiji
Newbie level 6
Newbie level 6
I installed HSPICE 2003.03 and IC5.0 in RH8.0. icfb starts up with the license loaded (checked under option=>licenses). License for HSPICE is loaded using lmgrd with this output
<too long so i just pasted the last part>
16:41:02 (avantd) Server started on localhost for: hspice
16:41:02 (avantd) encrypt hspicewin hsptest
16:41:02 (avantd) vlsi500 vlsi2000 gemini_hspice
16:41:02 (avantd) metawaveswin metawaves avanwaves
16:41:02 (avantd) avanwaveswin
So, I guess i have installed the licenses correctly.
But, when I ran simulation in Analog Environment, the results were not saved. With both transient and dc analysis enabled, there were no *.tr0 or *.sw0 in my psf directory.
Using HSPICE in command line to simulate the netlist created by "Creat Final" and with .option post, there are tr0 and sw0 files. And, they contained the correct results when I viewed them on Awaves on PC.
So, what must I do to make IC50 save my simulation results? Any idea would be greatly appreciated!!
Thanks in advance
