HELP: No data file generated by hspiceS simulation.
Hughes
Advanced Member level 3
unable to checkout cdsaawaves
I have installed Cadence IC 5.0.33 and hspice 2003.03 in Mandrake 9.2. When I choose hspiceS simulator in ADE to run a transient analysis, both CIW and simulatin log file show the simulation completed successfully. But I can't plot any signals. I am sure that I have choose "save all node voltage" option. But no data file created. I have search the simulation directory and found no .tr0 file.
Any one can help me? Thanks in advance.
hspice stimod
set
.OPTION POST
cjswg cjgate
Thank you, gerryhsu and hr_rezaee.
But I am talking about hspiceS for Cadence ADE. Usually Cadence generate the proper netlist automatically. We don't need to add .option post to the generated netlist, right? (It is necessary in standalone hspice simulation, but not in ADE).
Now I have found the problem, but no solution. It is stated in the "Known problem and solution":
PCR 556965: Hspice simulator does not support PSF output on Linux
Update-- August 29, 2003: Identified in IC 5.0.33
Description: On the LINUX platform, the current version of the Hspice simulator may not write valid PSF data after simulation. Therefore, the analog design environment post simulation processing (plotting, printing) may not work.
Solution:None.
So, no one use hspiceS in Cadence IC5.0 for Linux?
hi
Please read "Interface" in user manual of Hspice and you can take your answer.
if you have problem yet, contact me.
you could try hspice 2003.09.
Hi hr_rezaee,
Thanks for you advice. But I still don't know how to setup avanLink after reading the user manual (the section you refered can also be found at **broken link removed**
Hi xdlile,
I am using hspice 2003.09 with the above mentioned problem.
I have the same problem in hspice 2003.03.
There is no problem in hspice 2003.09.
This is my hspice.out
******  HSPICE    -- U-2003.09  (20030718) 11:43:39  08/13/2005  linux
  Copyright (C) 2003 Synopsys, Inc. All Rights Reserved.
  Unpublished-rights reserved under US copyright laws.
  This program is protected by law and is subject to the
  terms and conditions of the license agreement found in:
    /usr/local/EDA/U-2003.09/license.txt
  Use of this program is your acceptance to be bound by this
  license agreement. HSPICE is the trademark of Synopsys, Inc.
  Input File: raw/inveter
 lic:
 lic: FLEXlm: v6.1g
 lic: USER:   ****                 HOSTNAME: localhost.localdomain
 lic: HOSTID: *************         PID:      ****
 lic: Using FLEXlm license file:
 lic: /usr/local/EDA/U-2003.09/license.dat
 lic: Checkout hspice;  Encryption code: *******************
 lic: License/Maintenance for hspice will expire on 1-jan-0/2003.900
 lic: NODE LOCKED DEMO license on host **************
 lic:
 Init: read install configuration file: /usr/local/EDA/U-2003.09/meta.cfg
 Init: hspice initialization file: /usr/local/EDA/U-2003.09/hspice.ini
 * reading file:  /usr/local/eda/u-2003.09/hspice.ini
 .global vdd!
 * file name: test_inveter_schematic.s.
 * subcircuit for cell: inveter.
 * generated for: hspices.
 * generated on aug 13 11:43:35 2005.
 v1 vdd! 0  5.0
 c0 out 0  100e-15 m=1.0
 mp0 out net2 vdd! vdd!  tsmc35p  l=400e-9 w=600e-9 ad=600e-15 as=600e-15
 +pd=3.2e-6 ps=3.2e-6 m=1
 mn0 out net2 0 0  tsmc35n  l=400e-9 w=600e-9 ad=600e-15 as=600e-15 pd=3.2e-6
 +ps=3.2e-6 m=1
 v0 net2 0  pulse 5.0 0.0 1e-9 10e-9 10e-9 300e-9 600e-9
 .lib '/usr/local/eda/local/models/hspice/public/publicmodel/tsmc35n' nmos
 * run n88y
 .model tsmc35n nmos (     level   = 49
 +version = 3.1            tnom    = 27             tox     = 7.6e-9
 +xj      = 1.5e-7         nch     = 1.7e17         vth0    = 0.4964448
 +k1      = 0.5307769      k2      = 0.0199705      k3      = 0.2963637
 +k3b     = 0.2012165      w0      = 2.836319e-6    nlx     = 2.894802e-7
 +dvt0w   = 0              dvt1w   = 5.3e6          dvt2w   = -0.032
 +dvt0    = 0.112017       dvt1    = 0.2453972      dvt2    = -0.171915
 +u0      = 444.9381976    ua      = 2.921284e-10   ub      = 1.773281e-18
 +uc      = 7.067896e-11   vsat    = 1.130785e5     a0      = 1.1356246
 +ags     = 0.2810374      b0      = 2.844393e-7    b1      = 5e-6
 +keta    = -7.8181e-3     a1      = 0              a2      = 1
 +rdsw    = 925.2701982    prwg    = -1e-3          prwb    = -1e-3
 +wr      = 1              wint    = 7.186965e-8    lint    = 1.735515e-9
 +xl      = -2e-8          xw      = 0              dwg     = -1.712973e-8
 +dwb     = 5.851691e-9    voff    = -0.132935      nfactor = 0.5710974
 +cit     = 0              cdsc    = 8.607229e-4    cdscd   = 0
 +cdscb   = 0              eta0    = 2.128321e-3    etab    = 0
 +dsub    = 0.0257957      pclm    = 0.6766314      pdiblc1 = 1
 +pdiblc2 = 1.787424e-3    pdiblcb = 0              drout   = 0.7873539
 +pscbe1  = 6.973485e9     pscbe2  = 1.46235e-7     pvag    = 0.05
 +delta   = 0.01           mobmod  = 1              prt     = 0
 +ute     = -1.5           kt1     = -0.11          kt1l    = 0
 +kt2     = 0.022          ua1     = 4.31e-9        ub1     = -7.61e-18
 +uc1     = -5.6e-11       at      = 3.3e4          wl      = 0
 +wln     = 1              ww      = 0              wwn     = 1
 +wwl     = 0              ll      = 0              lln     = 1
 +lw      = 0              lwn     = 1              lwl     = 0
 +capmod  = 2              cgdo    = 1.96e-10       cgso    = 1.96e-10
 +cgbo    = 0              cj      = 9.276962e-4    pb      = 0.8157962
 +mj      = 0.3557696      cjsw    = 3.181055e-10   pbsw    = 0.6869149
 +mjsw    = 0.1            pvth0   = -0.0252481     prdsw   = -96.4502805
 +pk2     = -4.805372e-3   wketa   = -7.643187e-4   lketa   = -0.0129496      )
 .endl nmos
 .lib '/usr/local/eda/local/models/hspice/public/publicmodel/tsmc35p' pmos
 * run n88y
 .model tsmc35p pmos (     level   = 49
 +xj      = 1.5e-7         nch     = 1.7e17         vth0    = -0.6636594
 +k1      = 0.4564781      k2      = -0.019447      k3      = 39.382919
 +k3b     = -2.8930965     w0      = 2.655585e-6    nlx     = 1.51028e-7
 +dvt0    = 1.1744581      dvt1    = 0.7631128      dvt2    = -0.1035171
 +u0      = 151.3305606    ua      = 2.061211e-10   ub      = 1.823477e-18
 +uc      = -8.97321e-12   vsat    = 9.915604e4     a0      = 1.1210053
 +ags     = 0.3961954      b0      = 6.493139e-7    b1      = 4.273215e-6
 +keta    = -9.27e-3       a1      = 0              a2      = 1
 +rdsw    = 2.30725e3      prwg    = -1e-3          prwb    = 0
 +wr      = 1              wint    = 5.962233e-8    lint    = 4.30928e-9
 +xl      = -2e-8          xw      = 0              dwg     = -1.596201e-8
 +dwb     = 1.378919e-8    voff    = -0.15          nfactor = 2
 +cit     = 0              cdsc    = 6.593084e-4    cdscd   = 0
 +cdscb   = 0              eta0    = 0.0286461      etab    = 0
 +dsub    = 0.2436027      pclm    = 4.3597508      pdiblc1 = 7.447024e-4
 +pdiblc2 = 4.256073e-3    pdiblcb = 0              drout   = 0.0120292
 +pscbe1  = 1.347622e10    pscbe2  = 5e-9           pvag    = 3.669793
 +capmod  = 2              cgdo    = 2.307e-10      cgso    = 2.307e-10
 +cgbo    = 0              cj      = 1.420282e-3    pb      = 0.99
 +mj      = 0.5490877      cjsw    = 4.773605e-10   pbsw    = 0.99
 +mjsw    = 0.1997417      pvth0   = 6.58707e-3     prdsw   = -93.5582228
 +pk2     = 1.011593e-3    wketa   = -0.0101398     lketa   = 6.027967e-3     )
 .endl pmos
 * include files
 * end of netlist
 .tran  1.00000e-08 1.00000e-06 start=  0.0000
 .temp    25.0000
 .op
 .save
 .option  ingold=2 artist=2 psf=2
 +        probe=0
 .end
 lic:
 lic: FLEXlm: v6.1g
 lic: HOSTID: *********************         PID:      ******
 lic: No such feature exists Feature:       cdsaawaves License path:  /usr/local
 lic: Unable to checkout cdsaawaves
 lic:
 lic:
 lic: FLEXlm: v6.1g
 lic: USER:   lile                 HOSTNAME: localhost.localdomain
 lic: HOSTID:******************         PID:      5043
 lic: Checkout psf;  Encryption code: ******************
 lic: License/Maintenance for psf will expire on 1-jan-0/2003.900
 lic: NODE LOCKED DEMO license on host ***************
 lic:
 constants  - tnom         kt           vt           gapsi        ni
            2.981e+02    4.116e-21    2.569e-02    1.115e+00    1.256e+16
1 ******  HSPICE    -- U-2003.09  (20030718) 11:43:39  08/13/2005  linux
 * # file name: /home/lile/cadence/simulation/inveter/hspices/schematic/
  ******  mos   model parameters           tnom=  25.000 temp=  25.000
 ***        model parameters  model name:   0:tsmc35n  model type:nmos   ***
   *** general parameters ***
    deriv=   0.
   ***  level 49  model parameters  ***
      hspver=     2002.2               level=         49
     version=        3.1            paramchk=          0
      apwarn=          1                lite=          0
      vgslim=          0             binUnit=          1
      capMod=          2               xpart=          1
      mobMod=          1              nqsMod=          0
      stiMod=          0                 elm=          5
    sfvtflag=          0                 tox=    7.6e-09 meter
          xj=    1.5e-07 meter       binflag=          0
        lmin=          0 meter          lmax=          0 meter
        wmin=          0 meter          wmax=          0 meter
        lref=          0 meter          wref=          0 meter
        lint=1.73552e-09 meter          wint=7.18696e-08 meter
       lmult=          1               wmult=          1
          ll=          0                 lln=          1
          lw=          0                 lwn=          1
         lwl=          0                  wl=          0
         wln=          1                  ww=          0
         wwn=          1                 wwl=          0
         dwg=-1.71297e-08 m/V             dwb=5.85169e-09 m/V^1/2
          a0=    1.13562                 ags=   0.281037 V^-1
          b0=2.84439e-07 meter            b1=      5e-06 meter
        keta= -0.0078181 V^-1           voff=  -0.132935 V
       ngate=          0 cm^-3           vbx=          0 V
         vbm=         -3 V                xt=   1.55e-07 meter
        vth0=   0.496445 V               nch=    1.7e+17 cm^-3
        nsub=      6e+16 cm^-3           nlx= 2.8948e-07 meter
      gamma1=          0 V^-1/2       gamma2=          0 V^-1/2
          k1=   0.530777 V^1/2            k2=  0.0199705
          k3=   0.296364                 k3b=   0.201216 V^-1
          w0=2.83632e-06 meter          dvt0=   0.112017
        dvt1=   0.245397                dvt2=  -0.171915 V^-1
       dvt0w=          0 meter^-1      dvt1w=    5.3e+06 meter^-1
       dvt2w=     -0.032 V^-1           dsub=  0.0257957
        eta0= 0.00212832                etab=          0 V^-1
          u0=    444.938 cm^2/V/sec         ua=2.92128e-10 m/V
          ub=1.77328e-18 (m/V)^2          uc= 7.0679e-11 V^-1
        vsat=     113078 m/sec            a1=          0 v^-1
          a2=          1               delta=       0.01 V
        rdsw=     925.27 ohm-um         prwg=     -0.001 V^-1
        prwb=     -0.001 V^-1/2           wr=          1
        pclm=   0.676631             pdiblc1=          1
     pdiblc2= 0.00178742             pdiblcb=          0 V^-1
      pscbe1=6.97348e+09 V/m          pscbe2=1.46235e-07 V/m
       drout=   0.787354                pvag=       0.05
     nfactor=   0.571097                cdsc=0.000860723 f/m^2
       cdscb=          0 f/V/m^2       cdscd=          0 f/V/m^2
         cit=          0 f/m^2        alpha0=          0 m/V
       beta0=         30 V               dlc=1.73552e-09 meter
         dwc=7.18696e-08 meter           clc=      1e-07 meter
         cle=        0.6                cgso=   1.96e-10 f/m
        cgdo=   1.96e-10 f/m            cgbo=          0 f/m
        cgsl=          0 f/m            cgdl=          0 f/m
      ckappa=        0.6                  cf=8.75406e-11 f/m
         sk1=          0                 sk2=          0
          sl=      2e-06                  sw=      2e-06
           k=          0                tnom=     300.15 K
         kt1=      -0.11 V              kt1l=          0
         kt2=      0.022                 ute=       -1.5
         ua1=   4.31e-09 m/V             ub1=  -7.61e-18 (m/V)^2
         uc1=   -5.6e-11 m/V^2            at=      33000 m/s
         prt=          0
         using Berkeley noise model       noiMod=          1
        noia=      1e+20                noib=      50000
        noic=   -1.4e-12                  em=    4.1e+07
          ef=          1                  af=          1
          kf=          0              gdsnoi=-1.23457e-29
         using Hspice diodes            using ACM
         acm=         0                 hdif=         0 meter
        ldif=         0 meter             js=         0 amp/m^2
         jsw=         0 amp/m            xti=         0
           n=         1                   cj=0.000927696 f/m^2
          mj=   0.35577                   pb=  0.815796 V
        cjsw=3.18106e-10 f/m             mjsw=       0.1
         php=  0.815796 V               pbsw (not used)
      cjgate=3.18106e-10 f/m            cjswg (not used)
       mjswg (not used)                 pbswg (not used)
       lketa= -0.0129496               wketa=-0.000764319
       pvth0= -0.0252481                 pk2=-0.00480537
       prdsw=   -96.4503
 ***        model parameters  model name:   0:tsmc35p  model type:pmos   ***
    deriv=   0.
      apwarn=          1                lite=          0
      capMod=          2               xpart=          1
      mobMod=          1              nqsMod=          0
      stiMod=          0                 elm=          5
        lint=4.30928e-09 meter          wint=5.96223e-08 meter
       lmult=          1               wmult=          1
          ll=          0                 lln=          1
          lw=          0                 lwn=          1
         lwl=          0                  wl=          0
         wln=          1                  ww=          0
         wwn=          1                 wwl=          0
         dwg=-1.5962e-08 m/V             dwb=1.37892e-08 m/V^1/2
          a0=    1.12101                 ags=   0.396195 V^-1
          b0=6.49314e-07 meter            b1=4.27322e-06 meter
        keta=   -0.00927 V^-1           voff=      -0.15 V
        vth0=  -0.663659 V               nch=    1.7e+17 cm^-3
        nsub=      6e+16 cm^-3           nlx=1.51028e-07 meter
          k1=   0.456478 V^1/2            k2=  -0.019447
          k3=    39.3829                 k3b=    -2.8931 V^-1
          w0=2.65558e-06 meter          dvt0=    1.17446
        dvt1=   0.763113                dvt2=  -0.103517 V^-1
       dvt2w=     -0.032 V^-1           dsub=   0.243603
        eta0=  0.0286461                etab=          0 V^-1
          u0=    151.331 cm^2/V/sec         ua=2.06121e-10 m/V
          ub=1.82348e-18 (m/V)^2          uc=-8.97321e-12 V^-1
        vsat=      99156 m/sec            a1=          0 v^-1
          a2=          1               delta=       0.01 V
        rdsw=    2307.25 ohm-um         prwg=     -0.001 V^-1
        prwb=          0 V^-1/2           wr=          1
        pclm=    4.35975             pdiblc1=0.000744702
     pdiblc2= 0.00425607             pdiblcb=          0 V^-1
      pscbe1=1.34762e+10 V/m          pscbe2=      5e-09 V/m
       drout=  0.0120292                pvag=    3.66979
     nfactor=          2                cdsc=0.000659308 f/m^2
       beta0=         30 V               dlc=4.30928e-09 meter
         dwc=5.96223e-08 meter           clc=      1e-07 meter
         cle=        0.6                cgso=  2.307e-10 f/m
        cgdo=  2.307e-10 f/m            cgbo=          0 f/m
         sk1=          0                 sk2=          0
          sl=      2e-06                  sw=      2e-06
           k=          0                tnom=     300.15 K
         prt=          0
        noia=    9.9e+18                noib=       2400
        noic=    1.4e-12                  em=    4.1e+07
          ef=          1                  af=          1
         jsw=         0 amp/m            xti=         0
           n=         1                   cj=0.00142028 f/m^2
          mj=  0.549088                   pb=      0.99 V
        cjsw=4.77361e-10 f/m             mjsw=  0.199742
         php=      0.99 V               pbsw (not used)
      cjgate=4.77361e-10 f/m            cjswg (not used)
       lketa= 0.00602797               wketa= -0.0101398
       pvth0= 0.00658707                 pk2= 0.00101159
       prdsw=   -93.5582
 * # file name: /home/lile/cadence/simulation/inveter/hspices/schemtic/
  ******  circuit element summary          tnom=  25.000 temp=  25.000
 **** capacitors
 element name       0:c0
 node1              0:out
 node2              0:0
 model
 cap eff          1.000e-13
 tc1                0.
 tc2                0.
 scale            1.000e+00
 ic                 0.
 m                1.000e+00
 w                  0.
 l                  0.
 temp             2.500e+01
 **** independent sources
     name         node1        node2      dc volt    ac mag    ac phase    type
    0:v1         0:vdd!       0:0         5.000e+00    0.         0.      dc
    0:v0         0:net2       0:0         5.000e+00    0.         0.      pulse
             initial value   5.000e+00
             pulsed value.     0.
             delay time...   1.000e-09
             risetime.....   1.000e-08
             falltime.....   1.000e-08
             width........   3.000e-07
             period.......   6.000e-07
 **** mosfets
 **** BSIM3v3 Model (Level49 or Level53)
 element name       0:mp0          0:mn0
 drain              0:out          0:out
 gate               0:net2         0:net2
 source             0:vdd!         0:0
 bulk               0:vdd!         0:0
 model              0:tsmc35p      0:tsmc35n
 w eff              0.             0.
 l eff              0.             0.
 rd eff             0.             0.
 rs eff             0.             0.
 cdsat              0.             0.
 cssat              0.             0.
 capbd            2.380e-15      1.575e-15
 capbs            2.380e-15      1.575e-15
 aic
 nf               1.000e+00      1.000e+00
 sa                 0.             0.
 sb                 0.             0.
 sd                 0.             0.
 mulu0            1.000e+00      1.000e+00
 mulua            1.000e+00      1.000e+00
 mulub            1.000e+00      1.000e+00
  ******  temperature-adjusted values      tnom=  25.000 temp=  25.000
 constants  - temp         kt           vt           gapsi        ni
 *** capacitors
    name        eff val
 *** mosfet element parameters
 name           rd eff   rs eff   cdsat    cssat     vto      beta
  ******  operating point information      tnom=  25.000 temp=  25.000
 ***** operating point status is all       simulation time is     0.
    node    =voltage      node    =voltage      node    =voltage
 +0:net2    = 5.000e+00 0:out     = 2.252e-08 0:vdd!    = 5.000e+00
 ****  voltage sources
 subckt
 element  0:v1       0:v0
  volts    5.000e+00  5.000e+00
  current -1.004e-11    0.
  power    5.018e-11    0.
     total voltage source power dissipation=  5.018e-11       watts
 **** mosfets
 subckt
 element  0:mp0      0:mn0
 region       Cutoff     Linear
  id      -3.551e-14  1.004e-11
  ibs        0.         0.
  ibd        0.         0.
  vgs        0.       5.000e+00
  vds     -5.000e+00  2.252e-08
  vbs        0.         0.
  vth     -6.941e-01  5.010e-01
  vdsat   -4.215e-02  2.371e+00
  beta     8.211e-05  1.542e-04
  gam eff  4.818e-01  5.455e-01
  gm       8.771e-13  6.626e-13
  gds      1.775e-14  4.456e-04
  gmb      3.014e-13  7.186e-13
  cdtot    1.536e-15  2.731e-15
  cgtot    5.553e-16  1.040e-15
  cstot    2.531e-15  2.545e-15
  cbtot    4.014e-15  3.372e-15
  cgs      1.526e-16  5.148e-16
  cgd      1.491e-16  5.125e-16
 ***** operating point status is ,I4,x,  simulation time is   1.000e-06
 +0:net2    = 5.000e+00 0:out     = 8.450e-05 0:vdd!    = 5.000e+00
 subckt
 element  0:v1       0:v0
  current -5.096e-10 -2.368e-10
  power    2.548e-09  1.184e-09
     total voltage source power dissipation=  3.732e-09       watts
 **** mosfets
 subckt
 element  0:mp0      0:mn0
  id      -3.551e-14  3.766e-08
  ibs        0.         0.
  ibd        0.         0.
  vgs        0.       5.000e+00
  vds     -4.999e+00  8.450e-05
  vbs        0.         0.
  gm       8.770e-13  2.487e-09
  gds      1.775e-14  4.455e-04
  gmb      3.014e-13  2.697e-09
          ***** job concluded
  ******  job statistics summary           tnom=  25.000 temp=  25.000
           total memory used        159 kbytes
  # nodes =     4 # elements=     5
  # diodes=     0 # bjts    =     0 # jfets   =     0 # mosfets =     2
     analysis      time      # points  tot. iter  conv.iter
     op point          0.01         1         7
     transient         0.03       101       230        92 rev=    11
     readin            0.03
     errchk            0.01
     setup             0.00
     output            0.00
           total cpu time          0.08 seconds
               job started at  11:43:39  08/13/2005
               job ended   at  11:43:39  08/13/2005
 lic: Release hspice token(s)
 lic: Release psf token(s)
    Hughes
Hi xdlile,
Thank you very much. It's my fault. I am using hspice 2003.03, not hspice 2003.09.
I can't get hspice 2003.09 now. But I know the problem now with your help.
