1stFalloutBoy
Junior Member level 1
Help needed ppwith LED's from somone with a very simplistic knowledge of electronics.
I am a tech support person - not someone with a lot of knowledge when it comes to electronics, I have been asked to hook up LED indicators that monitor the Raid Controller on a companies LSI-9361-8i and I don't want to blow it up as that one card is worth $1600, I have found some information regarding the headers on the card and asked for info from broadcom who do the support for the cards, there response was as follows.
The header current is limited to 25 mA at 3.3V.
Keep in mind, however, that it was designed to drive an LED with a forward voltage drop which is typically around 2V, therefore pulling approximately 10 mA.
Now there are four headers in question 3 two pin headers and one 16 pin connector with 2 pins per led indicating drive missing/unconfigured/bad.
I don't know if this response is telling me that the header current is 25mA at 3.3v for all the headers combined i.e 25ma/11 LEDs = 2.27ma per LED which seems awfully low, or if it is 25mA per led. and as for the statement.
"Keep in mind, however, that it was designed to drive an LED with a forward voltage drop which is typically around 2V, therefore pulling approximately 10 mA" - I have no idea what this means.
Can someone help me out please?
