help needed with Continuous Wavelet Transform on chirp signal
radhikaa90
Newbie level 3
Newbie level 3
hi,
i need to perform Continuous wavelet transform(CWT) on Chirp signal of freq range 300khz to 800khz for 100e-6 time period and fs=20e6... The chirp signal is 1x2001 samples.. i used CWT command but it shows error " attempt to use script as a function..
i am new to the concept of CWT. I am not sure if what i got as an output for CWT using cwtext ( c=cwtext(s,6,morl) ); and CWT 1-D using toolbox.. i have attached screen shots of my output.. can anyone tell me if it is wrong or right?
Thank you
Attachement:
