Hello everyone ,
I m working on my senior project and I m in real need for help with programming dspic30f4011. I need to know how do I write a code for capturing volatge ands current from battery of 12 V.
I have already deisgn the circuitry to sense battery voltage and Current
My circuit has 2 output sugnals (current and voltage) which connect to the ADC channels of DSPIC ..
I also need to set the duty cycle and the output should be at PWM port of DSPIC which inturn is connected to the Mosfet gate driver..
If any one has feed backs or sample code to start with I would highly appreciate the effort ..
Thank You
An engineer in Need !!!
