Ralph6410
Newbie
I, like a lot of people have a garage door opener. And, like a lot of people likely wonder if the garage door is closed after they drive away. Did I or did I not activate the switch? So, it would be nice to have an indicator light that would tell me the switch was used in.. say the last 4~10 minutes.
So.. would like to have some help with the schematic required. Seems simple enough but what I think I want
The garage door opener is run by a 9 volt battery and would be the power supply for any additions.
Thank you for any advice
- When door opener is used > a timer is activated that turns on a small LED
