You're not asking for help, you are asking someone else to do your work for you. Not going to happen.Help needed in VHDL FSM sequence detector 0101
Draw fsm and write VHDL code for a system which has is single bit input x and two single bit outputs Y and Z. output of system is asserted logic 1 to Y and Z when system detects in input stream of serial bits 0111 or 0101 respectively
