Help needed in Parallel CRC implementation in VHDL(urgent)
pratibha m d
Junior Member level 3
parallel crc vhdl
I needed help to implement 32bit Parallel CRC in VHDL for IEEE 802.3 protocol.Plz let me know which material i have to refer for this and also help me in the coding.
thanks
[/i][/u][/quote][/code][/url]\][/GVideo][/youtube]
parallel crc generator vhdl
i think there is some material someone posted some time ago in Asic Methodologiessection........
just go through it..........
crc implementation in vhdl
Can anyone plz tell me the theory behind 32bit parallel CRC? i m not getting the basis on which the 32 bit CRC is being calculated in the code which is being generated in the CRC tool of wesite www.easics.com.
library IEEE;
use IEEE.std_logic_1164.all;
package PCK_CRC32_D8 is
-- polynomial: (0 1 2 4 5 7 8 10 11 12 16 22 23 26 32)
-- data width: 8
-- convention: the first serial data bit is D(7)
function nextCRC32_D8
( Data: std_logic_vector(7 downto 0);
CRC: std_logic_vector(31 downto 0) )
return std_logic_vector;
end PCK_CRC32_D8;
library IEEE;
package body PCK_CRC32_D8 is
-- data width: 8
return std_logic_vector is
variable D: std_logic_vector(7 downto 0);
variable C: std_logic_vector(31 downto 0);
variable NewCRC: std_logic_vector(31 downto 0);
begin
D := Data;
C := CRC;
NewCRC(0) := D(6) xor D(0) xor C(24) xor C(30);
NewCRC(1) := D(7) xor D(6) xor D(1) xor D(0) xor C(24) xor C(25) xor
C(30) xor C(31);
NewCRC(2) := D(7) xor D(6) xor D(2) xor D(1) xor D(0) xor C(24) xor
C(25) xor C(26) xor C(30) xor C(31);
NewCRC(3) := D(7) xor D(3) xor D(2) xor D(1) xor C(25) xor C(26) xor
C(27) xor C(31);
NewCRC(4) := D(6) xor D(4) xor D(3) xor D(2) xor D(0) xor C(24) xor
C(26) xor C(27) xor C(28) xor C(30);
NewCRC(5) := D(7) xor D(6) xor D(5) xor D(4) xor D(3) xor D(1) xor
D(0) xor C(24) xor C(25) xor C(27) xor C(28) xor C(29) xor
C(30) xor C(31);
NewCRC(6) := D(7) xor D(6) xor D(5) xor D(4) xor D(2) xor D(1) xor
C(25) xor C(26) xor C(28) xor C(29) xor C(30) xor C(31);
NewCRC(7) := D(7) xor D(5) xor D(3) xor D(2) xor D(0) xor C(24) xor
C(26) xor C(27) xor C(29) xor C(31);
NewCRC(8) := D(4) xor D(3) xor D(1) xor D(0) xor C(0) xor C(24) xor
C(25) xor C(27) xor C(28);
NewCRC(9) := D(5) xor D(4) xor D(2) xor D(1) xor C(1) xor C(25) xor
C(26) xor C(28) xor C(29);
NewCRC(10) := D(5) xor D(3) xor D(2) xor D(0) xor C(2) xor C(24) xor
C(26) xor C(27) xor C(29);
NewCRC(11) := D(4) xor D(3) xor D(1) xor D(0) xor C(3) xor C(24) xor
NewCRC(12) := D(6) xor D(5) xor D(4) xor D(2) xor D(1) xor D(0) xor
C(4) xor C(24) xor C(25) xor C(26) xor C(28) xor C(29) xor
C(30);
NewCRC(13) := D(7) xor D(6) xor D(5) xor D(3) xor D(2) xor D(1) xor
C(5) xor C(25) xor C(26) xor C(27) xor C(29) xor C(30) xor
C(31);
NewCRC(14) := D(7) xor D(6) xor D(4) xor D(3) xor D(2) xor C(6) xor
C(26) xor C(27) xor C(28) xor C(30) xor C(31);
NewCRC(15) := D(7) xor D(5) xor D(4) xor D(3) xor C(7) xor C(27) xor
C(28) xor C(29) xor C(31);
NewCRC(16) := D(5) xor D(4) xor D(0) xor C(8) xor C(24) xor C(28) xor
C(29);
NewCRC(17) := D(6) xor D(5) xor D(1) xor C(9) xor C(25) xor C(29) xor
C(30);
NewCRC(18) := D(7) xor D(6) xor D(2) xor C(10) xor C(26) xor C(30) xor
C(31);
NewCRC(19) := D(7) xor D(3) xor C(11) xor C(27) xor C(31);
NewCRC(20) := D(4) xor C(12) xor C(28);
NewCRC(21) := D(5) xor C(13) xor C(29);
NewCRC(22) := D(0) xor C(14) xor C(24);
NewCRC(23) := D(6) xor D(1) xor D(0) xor C(15) xor C(24) xor C(25) xor
C(30);
NewCRC(24) := D(7) xor D(2) xor D(1) xor C(16) xor C(25) xor C(26) xor
C(31);
NewCRC(25) := D(3) xor D(2) xor C(17) xor C(26) xor C(27);
NewCRC(26) := D(6) xor D(4) xor D(3) xor D(0) xor C(18) xor C(24) xor
NewCRC(27) := D(7) xor D(5) xor D(4) xor D(1) xor C(19) xor C(25) xor
NewCRC(28) := D(6) xor D(5) xor D(2) xor C(20) xor C(26) xor C(29) xor
C(30);
NewCRC(29) := D(7) xor D(6) xor D(3) xor C(21) xor C(27) xor C(30) xor
C(31);
NewCRC(30) := D(7) xor D(4) xor C(22) xor C(28) xor C(31);
NewCRC(31) := D(5) xor C(23) xor C(29);
return NewCRC;
end nextCRC32_D8;
end PCK_CRC32_D8;
Waiting for ur response.Plz help me.
Thanks
