Help needed in orcad spice
abo
Newbie level 1
Newbie level 1
I have a big problem in spice
my professor gave us a big assignment in spice and to solve it i need a component in spice that get's a file with data that conclude frequency, Voltage amplitude and phase and gives a voltage source (like pwl_file_source in time)
Please Respond...I'v also need help on this issu..
Johana
Johana
It´s not easy to respond since your problem is not quite clear to me. Sorry.
abo said:
... i need a component in spice that get's a file with data that conclude frequency, Voltage amplitude and phase and gives a voltage source (like in time)
If I understand you correctly, you need the SPICE syntax for a pwl_file_source which uses .DATA input, s. the hspice_models_quickref.pdf below, p. 8 resp. 12 .
