mzoh
Hello,
I am working on audio classification using svm and i found this code from link:
https://github.com/mosamdabhi/Voice...n-Speech-Recognition-System-Machine-Learning-
but its gving errors, data set is not shared in this code, i am using other data set, in svmtrain i am getting errors about
thisLab = str2num(Characterstring(1:end-4));
trainedSVM = svmtrain(net_TrainingSet,net_Labels);
error: svmtrain Y and TRAINING must have the same number of rows
i have made some changes in this code like wavread changed my audioread and some other function, please help me out to run this code.
% Author: Mosam
clc;
clear all;
close all;
listing = dir('C:\Users\hp\Downloads\Compressed\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Train1\*.wav');
for g=1:length(listing);
names{g} = listing(g).name;
end
labels=[];
TrainingSet=[];
Accuracy=[];
for xx=1:length(listing);
[x,Fs] = audioread([ 'C:\Users\hp\Downloads\Compressed\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Train1\' names{xx}]);
%N = length(x); % signal length
%n = 0:N-1;
%ts = n*(1/Fs); % time for signal
%wintype = 'rectwin';
Nlen = 320;
Nshft = 160;
steng=calsteng(x,Nlen,Nshft);
Characterstring = names{xx};
Characterstring = Characterstring(1:end-4);
labels = [labels thisLab];
GroupVariable = labels';
%labels_row = cellstr(R)
%y=1/x;
%disp([names{xx} num2str(length(steng))])
InitDiff = diff(steng(1:length(steng)));
InitDiffthreshold = (1/100)*max(steng);
max(InitDiff);
%M = max(find(abs(T) > (t)));
stengmin = min(find(abs(InitDiff) > (InitDiffthreshold)));
FlippedInitDiff = fliplr(InitDiff);
max(FlippedInitDiff);
Thresholdcut = find(abs(FlippedInitDiff) > (InitDiffthreshold), 1 );
stengmax = length(FlippedInitDiff)-Thresholdcut;
factor = length(x)/length(steng);
%i = stengmax;
xlimupper = factor*stengmax;
%j = stengmin;
xlimlower = factor*stengmin;
ax1 = subplot(3,1,1);
plot(x); hold on;
%# vertical line
hx = plot(xlimlower, 'LineStyle',':', 'Color',[.7 .7 .7]);
% changedependvar(hx,'x');
hx = plot(xlimupper, 'LineStyle',':', 'Color',[.7 .7 .7]);
hold off;
title(names{xx})
subplot(3,1,2);
plot(steng,'r');
ax2 = subplot(3,1,3);
%axis([3500,9625,-1,1]);
plot(x);
xlim(ax2,[xlimlower xlimupper]);
Tw = 25; % analysis frame duration (ms)
Ts = 10; % analysis frame shift (ms)
alpha = 0.97; % preemphasis coefficient
M = 20; % number of filterbank channels
C = 12; % number of cepstral coefficients
L = 22; % cepstral sine lifter parameter
LF = 300; % lower frequency limit (Hz)
HF = 3700; % upper frequency limit (Hz)
wav_file = ([ 'C:\Users\hp\Downloads\Compressed\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Train1\' names{xx}]); % input audio filename
[ speech, fs ] = audioread( wav_file );
% Feature extraction (feature vectors as columns)
% [ MFCCs, FBEs, frames ] = ...
% mfcc( speech, fs, Tw, Ts, alpha, @hamming, [LF HF], M, C+1, L );
% Generate data needed for plotting
[ Nw, NF ] = size( frames ); % frame length and number of frames
time_frames = [0:NF-1]*Ts*0.001+0.5*Nw/fs; % time vector (s) for frames
time = [ 0:length(speech)-1 ]/fs; % time vector (s) for signal samples
logFBEs = 20*log10( FBEs ); % compute log FBEs for plotting
logFBEs_floor = max(logFBEs(:))-50; % get logFBE floor 50 dB below max
logFBEs( logFBEs<logFBEs_floor ) = logFBEs_floor; % limit logFBE dynamic range
% Generate plots
%figure('Position', [30 30 800 600], 'PaperPositionMode', 'auto', ...
% 'color', 'w', 'PaperOrientation', 'landscape', 'Visible', 'on' );
ax2 = subplot(3,1,1);
plot(x);
xlabel( 'Time (s)' );
ylabel( 'Amplitude' );
title( 'Speech waveform');
subplot(3,1,2);
imagesc( time_frames, [1:M], logFBEs );
axis( 'xy' );
xlim( [ min(time_frames) max(time_frames) ] );
ylabel( 'Channel index' );
title( 'Log (mel) filterbank energies');
subplot(3,1,3);
imagesc( time_frames, [1:C], MFCCs(2:end,:) ); % HTK's TARGETKIND: MFCC
%imagesc( time_frames, [1:C+1], MFCCs ); % HTK's TARGETKIND: MFCC_0
%R = imagesc
axis( 'xy' );
ylabel( 'Cepstrum index' );
title( 'Mel frequency cepstrum' );
Energy = MFCCs';
R1 = Energy;
R1 = R1(1:15:length(Energy),:);
%Energy = MFCCs(4,:);
%R2 = Energy';
%R1 = R2;
%Feature1 = var(R1);
%Feature2 = mean(R1);
%CovarianceFeat = cov(R1);
%Feature3 = CovarianceFeat(:)';
%Feature4 = std(R1);
%CorrcoefFeat = corrcoef(R1);
%Feature5 = CorrcoefFeat(:)';
%Feature6 = mode(R1);
%Feature7 = median(R1);
%Feature8 = min(R1);
%Feature9 = max(R1);
%NetFeatures = [Feature1 Feature2 Feature3 Feature4 Feature6 Feature7 Feature8 Feature9];
TrainingSet = [R1; TrainingSet];
end
labels_rows = GroupVariable(:);
labels_appending_matrix = [];
for i1=1:size(TrainingSet,1)
labels_appending_matrix = [labels_rows; labels_appending_matrix];
end
listing3 = dir('C:\Users\hp\Downloads\Compressed\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Train2\*.wav');
for g3=1:length(listing3);
names{g3} = listing3(g3).name;
end
TrainingSet_Train2=[];
labels3=[];
for xx3=1:length(listing3);
[x3,Fs] = audioread([ 'C:\Users\hp\Downloads\Compressed\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Train2\' names{xx3}]);
%n = 0:N-1;
Nlen = 320;
Nshft = 160;
steng3=calsteng(x3,Nlen,Nshft);
Characterstring3 = names{xx3};
Characterstring3 = Characterstring3(1:end-4);
thisLab3 = str2num([Characterstring3(:)]);
labels3 = [labels3 thisLab3];
GroupVariable3 = labels3';
InitDiff3 = diff(steng3(1:length(steng3)));
InitDiffthreshold3 = (1/100)*max(steng3);
max(InitDiff3);
% M = max(find(abs(T) > (t)));
stengmin3 = find(abs(InitDiff3) > (InitDiffthreshold3), 1 );
FlippedInitDiff3 = fliplr(InitDiff3);
max(FlippedInitDiff3);
Thresholdcut3 = find(abs(FlippedInitDiff3) > (InitDiffthreshold3), 1 );
stengmax3 = length(FlippedInitDiff3)-Thresholdcut3;
factor3 = length(x3)/length(steng3);
%i = stengmax;
xlimupper3 = factor3*stengmax3;
%j = stengmin;
xlimlower3 = factor3*stengmin3;
ax123 = subplot(3,1,1);
plot(x3); hold on;
%# vertical line
hx3 = plot(xlimlower3, 'LineStyle',':', 'Color',[.7 .7 .7]);
% changedependvar(hx3,'x');
hx3 = plot(xlimupper3, 'LineStyle',':', 'Color',[.7 .7 .7]);
hold off;
title(names{xx3})
subplot(3,1,2);
plot(steng3,'r');
ax223 = subplot(3,1,3);
plot(x3);
xlim(ax223,[xlimlower3 xlimupper3])
wav_file = ([ 'C:\Users\hp\Downloads\Compressed\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Train2\' names{xx3}]); % input audio filename
[ speech3, fs3 ] = audioread( wav_file );
[ MFCCs3, FBEs3, frames3 ] = ...
mfcc( speech3, fs3, Tw, Ts, alpha, @hamming, [LF HF], M, C+1, L );
[ Nw3, NF3 ] = size( frames3 ); % frame length and number of frames
time_frames3 = [0:NF3-1]*Ts*0.001+0.5*Nw3/fs3; % time vector (s) for frames
time3 = [ 0:length(speech3)-1 ]/fs3; % time vector (s) for signal samples
logFBEs3 = 20*log10( FBEs3 ); % compute log FBEs for plotting
logFBEs_floor3 = max(logFBEs3(:))-50; % get logFBE floor 50 dB below max
logFBEs3( logFBEs3<logFBEs_floor3 ) = logFBEs_floor3; % limit logFBE dynamic range
% Generate plots
ax223 = subplot(3,1,1);
plot(x3);
xlim(ax223,[xlimlower3 xlimupper3]);
subplot(3,1,2);
imagesc( time_frames3, [1:M], logFBEs3 );
axis( 'xy' );
xlim( [ min(time_frames3) max(time_frames3) ] );
subplot(3,1,3);
imagesc( time_frames3, [1:C], MFCCs3(2:end,:) ); % HTK's TARGETKIND: MFCC
%R = imagesc
axis( 'xy' );
Energy3 = MFCCs3';
R3 = Energy3;
R3 = R3(1:15:length(Energy3),:);
%R223 = Energy3';
%R123 = R223;
%Feature1_3 = var(R123);
%Feature2_3 = mean(R123);
%CovarianceFeat = cov(R123);
%Feature3_3 = CovarianceFeat(:)';
%Feature4_3 = std(R123);
%CorrcoefFeat = corrcoef(R12);
%Feature5_2 = CorrcoefFeat(:)';
%Feature6_3 = mode(R123);
%Feature7_3 = median(R123);
%Feature8_3 = min(R123);
%Feature9_3 = max(R123);
%NetFeatures1_3 = [Feature1_3 Feature2_3 Feature3_3 Feature4_3 Feature6_3 Feature7_3 Feature8_3 Feature9_3];
TrainingSet_Train2 = [R3; TrainingSet_Train2];
end
labels_rows3 = GroupVariable3(:);
labels_appending_matrix3 = [];
for i3=1:size(TrainingSet_Train2,1)
labels_appending_matrix3 = [labels_rows3; labels_appending_matrix3];
end
net_TrainingSet = [TrainingSet; TrainingSet_Train2];
net_Labels = [labels_appending_matrix; labels_appending_matrix3];
testSet = dir('C:\Users\hp\Downloads\Compressed\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Test*.wav');
for g2=1:length(testSet);
names{g2} = testSet(g2).name;
end
TrainingSet_Test=[];
output=[];
labels2=[];
for xx2=1:length(testSet);
[x2,Fs] = audioread([ 'C:\Users\hp\Downloads\Compressed\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Test\' names{xx2}]);
%n = 0:N-1;
Nlen = 320;
Nshft = 160;
steng2=calsteng(x2,Nlen,Nshft);
Characterstring2 = names{xx2};
Characterstring2 = Characterstring2(1:end-4);
thisLab2 = str2num([Characterstring2(4)]);
labels2 = [labels2 thisLab2];
GroupVariable2 = labels2';
InitDiff2 = diff(steng2(1:length(steng2)));
InitDiffthreshold2 = (1/100)*max(steng2);
max(InitDiff2);
stengmin2 = min(find(abs(InitDiff2) > (InitDiffthreshold2)));
FlippedInitDiff2 = fliplr(InitDiff2);
max(FlippedInitDiff2);
Thresholdcut2 = min(find(abs(FlippedInitDiff2) > (InitDiffthreshold2)));
stengmax2 = length(FlippedInitDiff2)-Thresholdcut2;
factor2 = length(x2)/length(steng2);
%i = stengmax;
xlimupper2 = factor2*stengmax2;
%j = stengmin;
xlimlower2 = factor2*stengmin2;
ax12 = subplot(3,1,1);
plot(x2); hold on;
%# vertical line
hx2 = plot(xlimlower2, 'LineStyle',':', 'Color',[.7 .7 .7]);
%changedependvar(hx2,'x');
hx2 = plot(xlimupper2, 'LineStyle',':', 'Color',[.7 .7 .7]);
hold off;
title(names{xx2})
subplot(3,1,2);
plot(steng2,'r');
ax22 = subplot(3,1,3);
plot(x2);
xlim(ax22,[xlimlower2 xlimupper2])
wav_file = ([ 'C:\Users\hp\Downloads\Compressed\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Voice-Based-Digit-Recognition-Speech-Recognition-System-Machine-Learning--master\Test\' names{xx2}]); % input audio filename
[ speech2, fs2 ] = audioread( wav_file );
[ MFCCs2, FBEs2, frames2 ] = ...
mfcc( speech2, fs2, Tw, Ts, alpha, @hamming, [LF HF], M, C+1, L );
[ Nw2, NF2 ] = size( frames2 ); % frame length and number of frames
time_frames2 = [0:NF2-1]*Ts*0.001+0.5*Nw2/fs2; % time vector (s) for frames
time2 = [ 0:length(speech2)-1 ]/fs2; % time vector (s) for signal samples
logFBEs2 = 20*log10( FBEs2 ); % compute log FBEs for plotting
logFBEs_floor2 = max(logFBEs2(:))-50; % get logFBE floor 50 dB below max
logFBEs2( logFBEs2<logFBEs_floor2 ) = logFBEs_floor2; % limit logFBE dynamic range
% Generate plots
ax22 = subplot(3,1,1);
plot(x2);
xlim(ax22,[xlimlower2 xlimupper2]);
subplot(3,1,2);
imagesc( time_frames2, [1:M], logFBEs2 );
axis( 'xy' );
xlim( [ min(time_frames2) max(time_frames2) ] );
subplot(3,1,3);
imagesc( time_frames2, [1:C], MFCCs2(2:end,:) ); % HTK's TARGETKIND: MFCC
%R = imagesc
axis( 'xy' );
Energy2 = MFCCs2'
%Energy2 = MFCCs2';
%R2 = Energy2;
%R2 = R2(1:15:length(Energy2),:);
TrainingSet_Test = [Energy2; TrainingSet_Test];
end
%net_TrainingSet = [TrainingSet; TrainingSet_Train2];
labels_rows2 = GroupVariable2(1,:);
labels_appending_matrix2 = [];
for i2=1:size(TrainingSet_Test,1)
labels_appending_matrix2 = [labels_rows2; labels_appending_matrix2];
end
%trainedSVM = svmtrain(net_TrainingSet,net_Labels);
for i=1:size(TrainingSet_Test,1)
tmp = svmclassify(trainedSVM,TrainingSet_Test(i,:));
output = [output tmp];
end
%TRY=[];
output = mode(output)
%acctf = ((output-labels2)./labels2);
%accsum = sum(((acctf')/i)*100);
%accuracy = 100 - accsum;
TRY = [output' labels_appending_matrix2(1,:)];
EVAL = Evaluate(labels_appending_matrix2(1,:),output');
%stats = confusionmatStats(labels2,output);
%Accuracy = [output-labels]
%[svmstruct,level] = Train_DSVM(TrainingSet,GroupVariable)
