Learner
Full Member level 2
- Joined
- Nov 1, 2004
- Messages
- 133
- Helped
- 4
- Reputation
- 8
- Reaction score
- 2
- Trophy points
- 1,298
- Location
- Area 621.xxx
- Activity points
- 1,402
Hi guys,
I was wondering if anyone offer some advise in controlling a 6' LCD screen....
I have a SHARP LQ6RA02 6" TFT and I am looking to use the LCD as an oscilloscope and spectrum analyzer screen.
After looking at the data sheet, I have found that the LCD can work in either Pal and NTSC mode. I guess it is the same as using a computer/TV monitor as an CRO or spectrum analyzer but what I want is to use RGB seperately to display different things eg. Green for signal display, red for text, blue for scales.......
I guess I would need some memory to store infos such as text and screen scales but how would I go about to display that on the LCD with a ucontroller? I have done it with a small 2 line text LCD but one with this size is somehow quite different......
Is it possible to use a CRT just for displaying analog signal connecting to a probe without have to generate vertical and horizontal sync pulses? If so, can I assume it would be the same to control this LCD? Since it has the same 15 pin analog connector like a computer monitor.
Also, does anyone know how these pulses work eg. frequency and pulse width?
Any advise would be greatly appreaciated, thanks in advance!
:spoko:
:spoko:
