help needed about miller effect and feedback theory
qslazio
Full Member level 3
Full Member level 3
This is from gray's book<analysis and design of analog integrated circuit>page 567 figure 8.15b.
Now as I calculate the output impedance of the circuit with feedback following the steps in gray's book.
the output impedance will be decreased to (Zo//Rf//RL)/(1+T),and the T is loop gain of the circuit.
But on the other hand,when i follows miller equivalence,the resistance looking into Rf from output is Rf/(1-1/A),the A is the circuit voltage gain without Rf.Then the output impedance of the circuit with Rf should be (Zo//(Rf/(1-1/A))//RL),which is very close to Zo//Rf//RL when A is large.
Now these two method has inconsistency with the output impedance of circuit with feedback.
So I'd like to know why miller equivalence's result does not match the feedback one.
This is the schematic of the circuit
thanks!
The feedback resistor looks like Rf/Av to a source *feeding* the amp. Looking from the output the feedback resistor is just Rf.
yes,if the A >>1 so Rf/(1-A)~Rf/(-A) and Rf/(1-1/A)~Rf
this the miller effect impedance
but as the feedback point, negative feedback will reduce the output impedance by (1+T),which is not consistent the miller effect above ,so that is what i can not figure out yet
you mixed up the standing points. Who is your instructor?
qslazio's caculation is right.
It is an approximate result in the text book. As normal, the a is larger than ten, so the result in the text book is no worse than the result by qslazio.
What the text do is for simple the result.
