help neede(OSI layer)
asmat_ali
Newbie level 6
Newbie level 6
hi
When voice data packet is send over LAN then what will be the functionality of OSI layer?
what do you mean by OSI functionality ?
If you are refering to VoIP protocol stack, then a general architecture could be:
| UDP |
| IP |
| MAC |
| Ethernet |
There's no something called OSI layer , it's OSI Model ?
Data packet is in L3 , do the S.IP and D.IP is put in the headers
Then to L2 , Where the the Datalink source and destination addresses is put
Then to L1 , The "Sending bits" Layer , which is your Ethernet. .
This is the rule of each layer in short from L3 ---->L1
