Help need in PIC16F877A ADC values..
chwoei
Newbie level 6
Newbie level 6
adresh adresl
hi everyone,
i got some problem in getting the values in c programming for analog to digital input for PIC16F877A. Do anyone knows how to get the values when a infrared sensor(analog) is converted in Digital values? how to set the ports or any alogorithms needed in programing to get the values when different distance is detected.
Hope someone good in PIC could help!! :p... hope to hear from u guys soon..
Kind regards,
CHANG
adresl adresh
chwoei said:
hi everyone,
Kind regards,
CHANG
This code for CSS c compiler
#if defined(__PCM__)
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#elif defined(__PCH__)
#include <18F452.h>
#endif
void main() {
int i, value, min, max;
printf("Sampling:");
setup_port_a( ALL_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
do {
min=255;
max=0;
for(i=0; i<=30; ++i) {
delay_ms(100);
value = Read_ADC();
if(value<min)
min=value;
if(value>max)
max=value;
printf("\n\rMin: %2X Max: %2X\n\r",min,max);
} while (TRUE);
i hope it can help you
adresl
hi there,
thanks for the respond, but i am using a picc compiler, can i have a picc one? and also comments on the code... thanks.
adresl and adresh
hi, can i as wat is the value = Read_ADC(); <--- the function read_adc() from? issit form the header file? and how was it actually in a pic.. could u tell me which register in pic?
adresh ccs pic c + 10 bits
initialise PORTA's appropiate pin as "analog & input" in ADCON1 register and TRISA register.
select ADC Pin from which Analog value to read in ADCON0
a small delay
set ADGO bit
wait untill ADGO bit is cleared by hardware ( means ADC data is ready )
ADC Value = ADRESH * 256 + ADRESL
16f877a picc adc
hi,
thanks for the explaination. can u tell me how this works
thanks
pic16f877 do not responding
Hi!
The result generated by the ADC is 10 bit and is held in the ADRESH(high byte) and ADRESL(low byte). The result can be combined into a single 16bit variable(i.e integer)by using
when u multiply the contents of ADRESH with 256 it is actually shifted 8 times to the left and then u simply add the lower register to it to get the actual value.
i.e e.g if ADRESH=0X03; and ADRESL=0X0F;
then
ADC Value = (ADRESH<<8)|ADRESL;
will give the value of ADC Value = 0x030F;
which was the actual result.
hope this helps.
Regards.
Added after 2 minutes:
Hi!
Sorry for the smiley, i donot know how it got into that equation. The actual equation is
Regards.
Added after 4 minutes:
Sorry once again i cannot figure out why it is hapenning.
Regards.
Hello,
I'll tell you how to do this in assembly:
Provided that PIC16f877 uses 10 bit resolution for ADC, it implies that two registers ADRESH and ADRESL represent analog data with a maximum of (2^10) - 1 = 1023.
Now here's what to do:
Step 0. Make the ADRESH & ADRESL Right Justified (now 00000011 11111111 is same as 1023 in decimal)
Step 1. Store ADRESH to a local an 8 bit variable say R1
Step 2. Store ADRESL to another 8 bit local variable say R2
Given the above steps, you have R1 R2 which are two eight bit registers having the actual digital value of the analog input.
Step 3. Do a 16 bit subtraction between the read value and 03 FF (1023 in decimal) just like in the classical 8086 style and convert the difference into ASCII. At this point you can do a multiplication procedure to get the input voltage in decimal form.
Step 4. To convert to ASCII (A tip) you'll have to do 1000's, 100's, 10's and 1's subtraction from the two 8 bit registers one by one to get the exact ASCII values of the individual digits. These individual digits can then be sent directly to your lcd or be stored to RAM for later use.
Congratulations! You've just learnt how to handle 16 bit data in PIC assembly :)
