khankll
Junior Member level 2
hi
i have bought a xiaomi battery bank 10400 mah but it is fake. one of its cell is filled with sand.
others are of poor quality hardly 300-500mah each.
i looked at circuit board. there is an ic from tpower tp4221B . this is smart ic for liion battery charging.
i checked the cells voltage when it fully charged them .cells were charged to 4.2 volts then it stopped . charging current was 500 mah . input charger and its cable is fully capable of 2 ampere current (and tested as well ). so it means its charging at this little rate.
now i have soem good liion batteries but they are to be charged at 4.35 volts not at 4.2..
i looked at the ic specs it supports 1.3 Amp of charging current , 1 amp discharge, and supports both 4.2 and 4.35 volts chemistry liions.
it has been a lot of time since i did electronics. please help me in finding achieve above two purposes.
pictures of the circuit are uploaded .
some refrence to the data sheet are given below.
http://www.zjwic.com/upload/day_141201/201412011810438939.pdf
http://shopper.life/diy-xiaomi-10400mah-powerbank-3041.html#comment13297
