ee_control
Newbie level 5
help me .............................................
i need help for my project .
i need documentation for it
thank you for all
Project Description
This project is Wireless Data Acquisition system for surveillance of petroleum well (Monitoring and control) Where:
1. Sensors measuring cases then convert these measurements from analog to digital via ADC
2. Read these data by microcontroller PIC16F877 where there is program inside PIC its function read data then processes it then out it serially from determines port to Transceiver.
From transceiver at Petroleum well to transceiver at Control Room from the transceiver to computer with RS232 serial port
Inside computer there is software its function Display for monitoring and make comparison with set point. Where each sensor has special set point
If the input data over rang then must makes control for plant
3. Reverse last way from computer to transceiver in control room from this transceiver to transceiver at Petroleum well then to microcontroller from microcontroller output to relays for operate (Fan, Lamps and valves)
This was general idea for my project
thank you for all
Project Description
