beyerch
Newbie level 3
28F400 dual circuit?
I have an application I work with that stores all of its data (operating program code and memory storage <data>) on an Intel 28F400 memory chip. I was thinking about a way to allow for me to hook up two memory chips to the board so that I could switch between the two chips in real time. Basically each chip would have the same program code, but different data that I would like to alternate to and from.
The circuit should have logic to NOT switch in the middle of a read or write operation. I'm pretty much new to this stuff so to me this is pretty hard; however, from what I have read it really should be a matter of putting the two memory components in parallel and just switching the Enable Lines to signify which chip is actually active. The catch is to check the lines to make sure notihing is active when switching.
Can anyone out there either help me out with a simple schematic or would someone be willing to do this for some $$$. I would really like to try this idea out so please help!
Thanks
Charles
Thanks
Charles
