Help me with solving a Kirchhoffs law task
bantamm
Junior Member level 3
kirchhoff's law help
it is task 1 which pains me so.
I have completed the assignment, but am now told that task1 b & c are incorrect, and i cant figure out why.
i used the equations...
total current = 13/3.5 = 3.174
1ohm resistor = ItR1 = 3.714 x 1
0.5ohm resistor = ItR0.5 = 3.714 x 0.5
2 ohm resistor = ItR2 = 3.714 x 2
the answers i have, im told are wrong.
i'm now told that i have to use the equation E1-E2= IR1+IR2+IR3 for task 1b.
can you guys help?? this is driving me mad, as i thought iwas correct, and i need to get this assignment out of the way.
Re: kirchhoff's law help
Your mistake is
you assumed that the sum of the voltages is aplied to the sum of the resistors which is not the case, ach loop has to be calculated separatly by kirchhoff's law.
u have two loops. u need to use MESH analysis. check for currents from both voltage sources and then try it. use same procedure fo 8V source also. and then add currents for central resistor if direction of flow of current is same.
thanks for the help.
i realised what i had done wrong, and re- calculated, now the answer is correct.
Can u show the correct answer?
I think
a) I = 4/3
b) L=7/3V M=2/3 R=16/3
it seems i could have been wrong for task 1c. the power dissipated.
i used the equation P=VI
should i have used P=I(squared)R ???
You can use the superimposition theorem.
First for the first source 5V there is a circuit with
5v in series with the 1Ω, and both in paralell with .5||2 = 0.4Ω
The current due 5V Source = 5V/1.4 = 3.57 A
Voltage in the 1Ω = 1Ω *3.57A = 3.57V
Voltage in the 0.5Ω resistor = 5-3.57 = 1.43V
Current in the 0.5Ω resistor = 1.43v /0.5Ω = 2.86A
Current in the 2Ω resistor = 3.57A - 2.86A = 0.71A
Second for the source 8V there is a circuit with
1Ω ||0.5Ω = 0.33Ω
so i = 8/(2+0.33) = 3.43A
V in 2Ω = 3.43A* 2Ω = 6.86V
V in the other resistors = 8 - 6.86 = 1.14V
V IN 0.5Ω = 1.14/0.5 = 2.28A
Finnaly Vin 0.5Ω = 2.86A + 2.28A
and you can go on the same way to answear the rest of the questions
