Dec 26, 2004 #1 V vaf20 Full Member level 3 Joined Jan 27, 2003 Messages 174 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,296 Activity points 1,479 Solution to latch-up hi all i use following xilinx CPLD XC9500 9572+95218+95288 what can i do for lath up immunity in my board? tnx in advance
Jan 12, 2005 #2 M mic_huhu Member level 3 Joined Dec 16, 2004 Messages 63 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 499 Solution to latch-up what's your meaning?
Jan 12, 2005 #3 T telga Junior Member level 3 Joined Nov 1, 2004 Messages 25 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 207 Re: Solution to latch-up Hello, If you want remove the latch up phenomena, you must be sure that the signal on the component entry is never over the component voltage specifications. If you cannot guarantee this condition then you must force the entry current to be lower than the current that starts the parasitic thyristor. Hope this help you. Telga
