ulderico
Full Member level 2
![Full Member level 2](/styles/images/ranks/elevel2.gif)
matlab error
When I use matlab I have this error
Exception occurred during event dispatching:
java.lang.NullPointerException
at com.mathworks.ide.cmdline.CommandHistory$HistoryList.getCommentColorPref(CommandHistory.java:2101)
at com.mathworks.ide.cmdline.CommandHistory$HistoryList.<init>(CommandHistory.java:2087)
at com.mathworks.ide.cmdline.CommandHistory.<init>(CommandHistory.java:1488)
at com.mathworks.ide.cmdline.CommandHistory.addLine(CommandHistory.java:1135)
at com.mathworks.ide.cmdline.MatlabCommandWidget.sendCommand(MatlabCommandWidget.java:3533)
at com.mathworks.ide.cmdline.MatlabCommandWidget.doEnterKey(MatlabCommandWidget.java:4643)
at com.mathworks.ide.cmdline.MatlabCommandWidget.access$29(MatlabCommandWidget.java:4630)
at com.mathworks.ide.cmdline.MatlabCommandWidget$KeyEventHandler.doEmacsKeys(MatlabCommandWidget.java:4817)
at com.mathworks.ide.cmdline.MatlabCommandWidget$KeyEventHandler.keyPressed(MatlabCommandWidget.java:4784)
at java.awt.AWTEventMulticaster.keyPressed(Unknown Source)
at java.awt.Component.processKeyEvent(Unknown Source)
at com.mathworks.mwt.MWComponent.processKeyEvent(MWComponent.java:548)
at com.mathworks.mwt.text.MWTextView$TextCanvas.processKeyEvent(MWTextView.java:6810)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.processKeyEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
What is the solution?
