Help me with protocol for FSK which gets a radiolink
wolf69
Full Member level 1
ECC for Radiolink
Hi all,
I'm working on a Low Power Device (FSK) to get a radiolink at 9600bps at 868Mhz.
The protocol of the trasmission is simple:
start symbol, length,data, crc16. Usual total length is about 35 bytes.
The tranmission is controlled by a 18Mhz hcs08 microcontroller.
I'd like to implement a forward error correction code.
I was thinking about an hamming code (7,4), obviously obtaining a lower data rate.
Do you think there are better choices for this application?
Thank You and Bye!
