Help me with power estimation of a digital circuit under ADS
ckpun
Newbie level 2
Newbie level 2
mixed signal simulation
I would like to do a mixed signal simulation. The system under simulation has an ADC (sigma-delta type) attached with subsequent digital circuit (I have already written the digital part using verilog (RTL)).
Right now, I want to do a power estimation of my digital circuit, under a typical ADC. However, I don't have experience in analog circuitry. Is there a way that I only take care of the behaviorial structure of the ADC, and then mixed them together somehow with my verilog code, to do a realistic power estimation for digital circuit? :roll:
Any reply will be highly appreciated. :eek:
Thank you.
Carson
Spectre can do mixed-signal simulation. You can write a behavioral model for ADC with veriloga.
Re: mixed signal simulation
hsim and nanosim
Spectre & SpectreRF will be better in Mixed-Signal simulation, it can work with Verilog_A.
Try EverCAD's ADiT for your mixed signal.
They have
ADiT (Turbo) for big-A.
It can co-sim with NC-Verilog, VCS or modelsim.
Or you can use EverCAD's ADiT-HDL and ADiT-Turbo.
the website is www.evercad.com
Check it out.
I like it.. easy configuration/set up..
spectre Verilog should ok
