Help me with my T&H circuit (SFDR and clock issues)
wael_wael
Full Member level 4
Full Member level 4
Help in T&H circuit
i have designed OTA with following specifications:
Dc gain=72db, phase =62, fu=230Mhz
so i used switch capacitor architecture with the obove OTA, switches are designed by transmission gate techniuqe,
the problem is the SFDR, around 45db. also the clock designed for 100p rise time and fall time, how to increase the SFDR.
fs=5oMSps, resoluation=10 bit
pest regards
Help in T&H circuit
The timing of s/h is no-overlap? There is a large harmonic in your circuit. check the harmonic frequency. The do .tran simulation, check the SC-op settling.
    wael_wael
Re: Help in T&H circuit
no the clock over lapping output, but the settling time was not good enouph, i will increase the current of hole circuit to get required settling time
thanx
Help in T&H circuit
The sample and hold colck should high level no overlapping. and check the sample timing, CM switch should turn off first then sample switch turn off and then hold switch on. that can reduce the charge injection and clock feedthrough.
well, the clock rise time and fall time around 60 ps, the diferent between the clocks around 47p, i didnt use commone switch
regards
How much time betteen that?
or How to deside it?
    wael_wael
i have small problem that is the clock has dalay 1 ns, the clock total time is 20 ns. can the clock dalay effect the SFDR
regards
