Help me with making a basic 4 switch robot
shadeslayer
Member level 2
Member level 2
hi i m planing to make basic robo i.e. with only 4 wheels ,, and i want to use wired remote with having 4 switches ,,forward,backword,left and right ,,, i wanto to use singel supply varing between 15v to 28v
can anybody tell me which ic i shuld use to drive relasy in my remote or can anybody give me the ckt dig of that
Re: basic 4 switch robo
Hi Shadeslayer.
I'm quit a fan of robotic. I would like to give some suggestion, but before that, please let me know:
1. What kind of motor you going to use? (dc, stepper, hobby servo)
2. How many motor you would like to use? (2 unit or 4 unit)
3. What is the robot movement ability? [car like(anchorman), wheelchair like(braitenberg), tank like(skip-steer)]
Doing project step by step will teach you more, rather then skipping importance procedure.
'Learn till you die'
Pian
pian said:
Hi Shadeslayer.
Pian
and...
please tell
4. which MCU you are going to use ? and
5.with which language you are comfertable form microcontroller programming..?
For simple EM relays you could use some high current drivers like ULN2003.
basic 4 switch robo
see i want to make a very basic model ,, with out programing ,,
using 4 dc moters ,,, and a wired remote to handel ,,
i made one with 2 switcher giving four function
now i want to make 4 switch one left right fwd and back ,,,
I've designed a simple schematic, use it for your robot application.
It will work
basic 4 switch robo
its .dsn file ,,, can u tell me in which soft it will open??
This file (.dsn) is a Proteus simulation file.If you install the Proteus Software and double click on this .dsn file,this file will automatically open in ISIS7 of Proteus and you can see the simulation
www.labcenter.com
__________________________________________________________________________________
You have your way. I have my way. As for the right way, the correct way, and the only way, it does not exist.
Friedrich Nietzsche
