Help me with LED matrix interface
shagy2003
Newbie level 2
Newbie level 2
I want to Interface LED matrix kit(SLS product) on expansion headers of UP3( Altera's ESDK) kit.The kit should be connected with the PC via RS232 on serial port.
The input to the board should be given via Hyper terminal from PC.So whatever characters Input from the keyboard should be displayed on the LED matrix.
1)Please tell me exact procedure to do the task.
2)I m not gettin function of the level translator IC(U21) which is max 3243c so please tell me exact function and output data format of the same.
3)ESDK supports UART or not?If yes then wat should be the procedure?Can u plese send some literature on ESDK UART?
4)Can u please give me some sample verilog code of LED matrix-ESDK interface?or give some logic,look up table for the same.
For ur reference I'm attaching the schematic diagram of the LED matrix.
Thanking you in advance,
Regards,
Sagar
LED matrix Interface
is it Possible share the Example Code & Doc
